Exposure problem
Posted 12/07/2010 - 15:54
Maybe try the firmware update as per JohnX - and putt the file in the root of the card AND make sure you have a fully charged battery in the camera before doing the update and leav it until its finished. Otherwise it sounds as though there may be a focus drive problem which could mean a repair job.
One other thought - have you a Rocket Blower? If so you could try removing lens and select dust removal from Menu. This raises the mirror and exposes the sensor for cleaning. BUT what I wonder if its worth gently blowing into the small pit underneath the mirror box where the AF sensor sits just in case some dust is in there and confusing it
But be careful - you don't want to end up blowing dust onto the sensor!
Andy
Andy
Andy
Posted 12/07/2010 - 18:14
karlh wrote:
MattMatic: have checked the pins after having left the battery out for about an hour. The pins work as you said: When in AF.S and AF.C, the focus driver retracts. In MF, it is flush with the body.
Do you mean the focus drive (shaft) protrudes when in AF.S and AF.C? If so, that's correct. If it's flush with the mount, it's wrong!
Alfpics:have no blower, so will do as JohnX suggests. Have specially charged battery for the purpose. And will move the fle outside the DMIC folder.
If it all explodes, so be it... the World has to come to an end somehow... will let you know when done...
Posted 12/07/2010 - 18:24
MattMatic: Try pressing the "AF" button on the back of the K20D. If it makes the same noise when you press just the AF button then it's a focus issue
(Normally the camera will auto focus when you half-press the shutter, but this can be adjusted in the custom menus)
As I said, you are right. It makes the same noise..what adjustment could I try before going through the update?
Any ideas on this, before I update?
Posted 12/07/2010 - 18:36
Since you said any ideas, I always kick against things that don't work, sometimes it helps but more often not but at least you have released some frustration. As I said, you are right. It makes the same noise..what adjustment could I try before going through the update?
polchraine already said it but have you left the battery out for a couple of hours, with that you also reset some options/features of the camera.
Posted 12/07/2010 - 22:32
anvh: have left the battery out for some four hours. Still purrs. So I think I should do the update?
Posted 13/07/2010 - 06:06
Just to confirm to Johnx: when in AF.S and AF.C, the focus drive PROTRUDES, when in MF, it is FLUSH. Which is correct.
will do the upgarde today, using Anvh's pdf. The upgrade came with a readme.txt file.
will let you know what happens.
Posted 13/07/2010 - 06:30
Have successfully upgraded, using the pdf instructions. Very clear guide, must say...idiot proof, to boot...
Now, I can use the AF.S option, but ONLY in the Preview mode. I have to focus manually. If not in Preview, it still purrrrrs along.
Any ideas?
Any ideas?
Posted 13/07/2010 - 08:27
Not much to suggest - but you have to weigh up whether to use it as it is albeit a pain and get some pictures or chance making it worse and getting no pictures.
Posted 13/07/2010 - 09:01
Like polchraine, nothing further to suggest. Would suggest using it in MF mode until you get home and then get it looked at
Andy
Andy
Andy
Posted 13/07/2010 - 09:52
Question: Does the lens actually focus while it is "purrrring"? (ie does the focus ring move)
Question: Does this happen with both the 18-55 and the 50-200? (If it only happens on one lens then maybe you have a focus clutch problem. You can check the lens: hold the lens so you are looking at the mount end, with the red dot at 12o'clock. At about 7o'clock the focus screw slot should be clearly visible, and you should be able to freely rotate this with a small screwdriver - you'll see the focus ring move.)
Question: Have you tried different focus points (ie switch the focus selector from auto-all-points, to centre-point). Maybe you have an issue with just part of the AF system (maybe the camera thinks it still needs to get a lock).
Question: When you use MF, while you half press the shutter, does the green hexagon appear in the viewfinder indicating focus lock? (This test will show whether the electronics used for the focus detection are working correctly)
You can disable the Auto-focus-on-half-press in the custom menu (or switch to MF). That should at least let you take photos, albeit in MF.
Posted 13/07/2010 - 12:54
ABOSULUTELY STRANGE. Just returned from the surrounding hills and used only MF. On return uploaded images to PC and also deleted the upgrade file from the card.
When I read MattMatic's post, I found that the focus ring was actually moving, focusing, I guess. But, much more, it actually focuses and activates the shutter. What a surprise when I saw properly focused images on my review.
Guess, the Czech mountain gremlins have left..... it seems to be working fine...
so, what's left? Just to say many thanks to all of you for your suggestions. Really appreciated, particularly so far from home. That's the advantage of the wide web, I guess...
Posted 13/07/2010 - 13:18
Could have been some grit, grease (or none) or temperature had caused to components to shrink/grow and they had locked together.
Probably the gentle fiddling you have done along with maybe a temperature change or two has cleared the problem.
Notting Hill,
London
When in AF.S it makes same purring noise as when I press the AF button on the back of the body.
Now the shutter works in AF.C and MF...
What next guys? Oh, btw, thanks for all the comments and suggestions, seems that I am getting there slowly, in the mountains of North Czech Republic....
