does any of my lenses work on Full frame cameras?
Posted 19/12/2011 - 12:57
Partially covered in this thread at pentaxforums.com: DA lenses on Full Frame: Test Shots thread
Posted 19/12/2011 - 12:58
They will probably be obsolete by the time a Pentax FF comes
out.... they haven't even started the design process yet
Posted 19/12/2011 - 13:16
either the link doesnt work or the forum is down...
but i will check it out!
thanks!
Pierre
thanks!
Pierre
Digital: KP, Film: KX, ME Super
Sigma 10-20mm f4-5.6, Tamron 17-50mm f2.8, Pentax 16-85mm, Pentax DA 20-40 ltd
Pentax 21mm f3.2 ltd, Sigma 24mm f2.8 macro, Pentax 28mm f2.8, Pentax 35mm f2.8 macro, Pentax 43mm f1.9 LTD, Pentax 50mm FA f1.7, Pentax A 50mm f1.7, Pentax K 55mm f1.8, Pentax DA* 55mm f1.4
Metz 36 AF-4
Metz 36 AF-4
Posted 19/12/2011 - 13:41
The Sigma 10-20 works - through some of the zoom range it does vignette, but I think it's OK from 15mm upwards. The Tamron 17-50mm definitely does not work - the imaging circle is about the same through the zoom range. The other zoom I've tested is the 18-55 kit lens... seems OK from about 28mm up.
The DA55-300 is noted as compatible here: http://ricehigh.blogspot.com/2009/10/compatibility-of-da-lenses-on-full.html
Posted 19/12/2011 - 13:47
Are you asking in the hope of a Pentax FF, trying an old Pentax film, or are you purchasing another brand? In which case compatibility/convenience is an issue
Pentax pour des images riches en détails!
Posted 19/12/2011 - 14:08
It is important to remember that just because there is no obvious vignetting, does not mean that the lens is suitable for full frame. There may well be significant loss of IQ beyond the designed for image circle.
The only lens I have, that I have on your list is the DA 55 - 300 and it does not show significant vignetting throughout the range on a ME Super.
FYI the DA 16-45 gives good results from around 22mm
Regards - Steve
Regards - Steve
Posted 19/12/2011 - 14:50
that means on a FF you can use 22mm which is better than 16mm (i.e 24mm 35mm equivalent) on the APS-C?
if so that's actually good news!!
Metz 36 AF-4
Metz 36 AF-4
Posted 19/12/2011 - 15:35
thanks!
Pierre
link is (more than likely) OK; I don't get a 404 error There seem to be problems currently where one can not access threads.
thanks!
Pierre
Posted 19/12/2011 - 17:09
I do not have any digitised images of my own, but here is a link to some images sent to me by mattmatic a few years back, when I made an enquiry re DA 16-45 on 35mm film link that means on a FF you can use 22mm which is better than 16mm (i.e 24mm 35mm equivalent) on the APS-C?
Note to Matt, I hope you don't mind mee sharing this.
Regards - Steve
Berlin
- 10-17 fisheye
- 10-20 sigma
- 17-50 f2.8 sigma
- 50-150 f2.8 sigma
- 55-300 pentax
- 18-250 tamron
my god since when do i have so many lenses!? might need to downsize a bit at some point..
Metz 36 AF-4
