DNG
Posted 23/06/2013 - 19:08 Link
I have recently purchased a K20D . I took some photos in green mode.These were stored as DNG files . My laptop does not recognise this file extension .I am having difficulty in finding software which would read this file. Nadeem
steven9761
Posted 23/06/2013 - 19:14 Link
Nadeem - go to this link and download the relevant file (Win or Mac). You should then be able to convert your dng files to jpeg.
mivoligo
Posted 23/06/2013 - 19:16 Link
If you use Windows, you can try FastStone Image Viewer http://www.faststone.org/FSViewerDetail.htm If you use Linux, you can go with Geeqie or darktable.
Edited by mivoligo: 23/06/2013 - 19:17
bettyswolloks
The software that came with the K20 perhaps mate? The dng extension is the standard adobe raw format so I'd say any adobe product will work pefrectly, I can recomend Lightroom just to name one, hope this helps Nadeem.
bettyswolloks
Posted 23/06/2013 - 19:18 Link
Gamka
Posted 23/06/2013 - 19:43 Link
Set the camera to save as RAW+ - which will give you a DNG or PEF along with a JPG. You can also set the resolution and compression of the JPG.
As this is a second hand camera, did you do a full reset when received? It may have non-standard settings that the previous owner worked with and may not be right for you.
Posted 23/06/2013 - 22:19 Link
bettyswolloks....the software disc was not included,with the camera.
Frogherder
Posted 23/06/2013 - 22:36 Link
You can download a RAW thumbnail reader from :-
http://www.microsoft.com/en-gb/download/details.aspx?id=26829
It won't help you process the pictures, but it will enable you to see them within whatever folder you've stored them in.
regards
Bernard
montyaus
Posted 24/06/2013 - 02:09 Link
You can go to the Pentax Web site and download Pentax Digital camera utility 4.
There is a tutorial by McGregor in General Digital Photography Chat Forum that will help you with this program.
Some zooms
https://pentaxphotogallery.com/artists/jack" target="_blank">http://c759846.r46.cf2.rackcdn.com/img/black_link.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Mannesty
Posted 24/06/2013 - 05:20 Link
That's probably an upgrade/update version and you'd need the original CD or serial number to load it.
Gamka
Posted 24/06/2013 - 09:39 Link
No, there is a "trick" that another member pointed me to. Get a USB/pen drive and give that drive a specific name (cannot remember what - but a search back to around January will find it) and have that inserted when running PDCU4 set up.
Name the USB drive S-SW90
The thread is: HERE
Edited by Gamka: 24/06/2013 - 09:45
Posted 27/06/2013 - 22:03 Link
cheers guys photo are now recognised.
sbrads
Posted 03/07/2013 - 19:43 Link
S-SW90 works. You don't even have to do anything with the USB stick other than have it plugged in while installing PDCU4.
I got PDCU from here in case it makes a difference.....link
