DigitaLIZA
Hardgravity
Posted 16/09/2012 - 10:35 Link
I came across these from LOMO on ebay, the LOMO site isn't any more informative so..
...does it work with a normal scanner?
Can it take 110and 35mm?
Any thoughts?
Oh, the link to the LOMO site is here
I only ask as scanning old 110 and the like films is always usefull, seeing as there's a new interest in the Pentax 110.
Cheers, HG
PPG entries.
DoctorJeff
Posted 16/09/2012 - 11:07 Link
I was always under the impression that you needed a light source "above" the negative to enable proper scanning.
Otherwise, you could just lay the neg straight onto the scanner glass (thinks to self - must try this and see what happens). Of course, the average document scanner will not have the resolution of a dedicated neg scanner (but that would never bother the Lomo gang).
Geoff
X-5
istDS
K2000
P50.
Hardgravity
Posted 16/09/2012 - 11:19 Link
After posting I did a bit more searching.
Seems these are for use with back lit scanners, ie. ones that can already do negatives!
If you try scanning neg's Jeff all you get is a black oblong.
I was only interested in the 110 side, but ...
Cheers, HG
PPG entries.
Algernon
Posted 16/09/2012 - 11:33 Link
Just put a lightbox on top of the scanner?
There used to be independent scanner covers with
lights built in.
My Epson has a built in light and 35mm + 120 masks.
womble
Posted 16/09/2012 - 12:25 Link
If you have a lightbox and some form of camera support (ideally a copystand) just pop the neg on the lightbox and photograph it with your dSLR. The invert function in Photoshop will turn it into a positive. You'll have to adjust the white balance somehow but if you can find one neg with something white in it you can use the custom white balance for them all.
For 110 negs you'll need a macro lens or tubes or something!
K.
Posted 16/09/2012 - 17:04 Link
The Summit PhotoFix SPS is a small negative scanner costing around £100. It will scan negatives and slides in 35mm and 110 format.
