da18-135
hi all.after reading terrible reviews for the 18-135 wr lens is it worth buying and will it work on a k500?
Not sure what reviews you may have read but user reviews seem to rate it highly, e.g. http://www.bhphotovideo.com/c/product/740381-USA/Pentax_21977_SMC_DA_18_135mm_F_...
The bad reviews reflect its launch price when it did appear poor value compared to other similar lenses (eg Pentax and Tamron 18-250's.) Don't ever remember hearing it described as terrible though. Where did you see that?
re K500, I'd presume it's compatible but have never personally seen one let alone tried one! Sorry about that.
When you do that then you'll buy one - it has put my 16-5Omm DA* and 50-135mm DA* into semi retirement for travel but as i have said on numerous times before, look at the cat portrait on my portfolio and you will see it is seriously good.
i wouldn't leave the house without it.
Daronl
Not as sharp as the limited's or DA*'s, but nevertheless it's plenty good enough and a very convenient focal length when you want to travel light or you're not sure what lens to take. It's well worth having.
I've been toying with the idea of selling it because I don't use it that much, but then I think how handy the FL is and keep having second thoughts!
The 18-135 is an incredible bargain at it's existing price and I've never had a WR lens fail due to the weather. Better optically than the three other priced (existing) entry level WR lenses. Not as good optically (or aperture) as the 24-70 limited, the 16-85 (one of Pentax's better zoom lenses), or the three other higher priced models.
The only two drawbacks about the 18-135 are the general terrible apertures of most of the WR line (unless one is willing to pay out the literal price and also the price in size and weight), and that it is not as good optically as two of the existing WR lenses that have been released within the last year
K3ii, K-5, K-x, DA150-450mm, DA16-85WR, DA16-45, DA18-55WR, DA18-135WR, DA35 F2.4, M100mm F4 Macro, DA55-300mm, FA50mm 1.4, AF360 Flash, AF540 Flash
Pjy123
Member
Kibworth harcourt
