DA*50-135 SDM noises - is it a cause for concern?
Posted 22/12/2009 - 16:48
Presumably you have checked that both the body and lens are set to autofocus :
It is easy to forget to switch back if you use manual focus (for macro work for example).
Hyram
Posted 22/12/2009 - 16:52
Yes autofocus was set correctly on both body and lens.
K20D | DA*16-50 | DA*50-135
MacBook Pro | Dell U2410 Monitor | Wacom Tablet
Canterbury
Autofocus worked fine with SDM but the lens kept making little clicking noises while it was focussing. The noises were not loud but definitely there - they sounded a bit like metal drawing pins dropping on a table top. My DA*16-50 SDM definitely does not make the same noises when autofocusing.
Are these noises anything to be worried about or not? At least is was purchased from SRS so there should not be any difficulty getting it sorted if that's necessary.
