DA* 50-135 motor failure
Posted 07/07/2013 - 13:00
If you are feeling brave you could try and fix it yourelf.
http://ricehigh.blogspot.com/2011/01/repair-stuck-sdm-yourself.html
I think i would be a bit scared though, I seemed to recal a couple of people who had sent theirs for repare saying that it came back working faster than before
I bought a 50-135mm with non working SDM a few months ago on purpose because it was cheap. It was repaired by JPS Solutions at a charge of £160. As you are a PU member you get 20% discount LINK so in the end it worked out at around £130.
On the plus side the lens came back much much better than previous working 50-135's I have had ... so much so I sold the Sigma 50-150mm f2.8 I was using.
Posted 07/07/2013 - 15:22
Have you tried cleaning the contacts? worth a try. I also have a lens with temperamental SDM, but I find that if I mount the lens and then (reasonably) gently spin the focus ring back and forth from closest to furthest a few times, the SDM works again; not sure why but it does the job for me...
Posted 07/07/2013 - 16:04
Thanks for the advice everyone. The motor failed after I took the lens with me to Greece, so I'm thinking it was not a big fan of the heat
I don't have the bottle to open it up myself, so I will check out the JPS option.
Thanks again,
Tim.
Thanks again,
Tim.
A man with narcolepsy, and a camera
Posted 07/07/2013 - 21:03
Tim
Like Mike, I had my copy fixed at JPS a couple of years ago. All perfectly straightforward and pretty fast.
I am intrigued by your location, as I studied at St David's University College (as it was then then) in the early 70s.
Posted 07/07/2013 - 21:38
Ah SDUC, later to be University of Wales, Lampeter, and now Trinity Saint Davids. I too did my degree years there, and later moved back to the area after finding London too 'much'. It's a lovely bit of the world, especially with the weather we are getting right now
Neath,
South Wales
Can anybody help me with what I should do now? Obviously it is outside of any warranty period, so I am looking at paying to get it fixed I guess. Money is limited though, so I have to be careful.
Any recommendations for who I should go to? I live in West Wales and don't drive, so getting anywhere is problematic.
Many thanks,
Tim.
