battery grip does not work
Posted 03/07/2013 - 09:20 Link
Hello.....I have recently purchased K20D with a battery grip.when i attach the grip the body recognise this however i cannot get this to shoot. Any Sugestions?
Also i have noticed some dirt specs and hair in the viewfinder is there any way this can be cleaned?Is it not surprising that a sealed camera allows dirt particles into the viewfinder. Regards
Posted 03/07/2013 - 10:45 Link
Grip: the grip functions only work when the power switch on the grip is ON (and the body is on too)
Dirt: a RocketBlower does the trick. However, make sure you give the blower a few hard puffs first before using on the mirror etc (to dislodge any dust in the blower itself).
HTH!
Edited by MattMatic: 03/07/2013 - 10:45
senn
Posted 03/07/2013 - 10:56 Link
Grip: it depends, .. if you can't shoot with body shutter while grip attached (whichever it's on or off) then there must be a problem; .. if you can't shoot with grip shutter then MattMatic is probably right
senn
my flickr gallery
my PPG
Edited by senn: 03/07/2013 - 10:57
fritzthedog
Posted 03/07/2013 - 13:26 Link
Re dust in view finder - you can remove the focus screen - this is a bit finicky and you will need nylon tipped tweezers or similar implements. You can then very carefully use a rocket blower in the chamber. Or get it done professionally or like most of us - ignore the dust it is doing no harm.
re battery grip - assuming you have switched it on - the most common problem is that one or more of the connection pins has become bent or jammed - check the pins - if they do not all line up or one or more remain retracted - that's your problem.
If it is the pins - clean them with alcohol and if jammed in - carefully try to release them - I have managed to do this with a sewing needle.
Good luck
Carl
Posted 03/07/2013 - 13:49 Link
one of the pins is jammed in. cheers Nadeem
Posted 03/07/2013 - 17:14 Link
fritzthedog What type of alcohol is best?
I have a 15year single malt at home, but that is for drinking.
Regards.
Nadeem
Gamka
Posted 03/07/2013 - 17:36 Link
Regards.
Nadeem
If you don't have any "cleaning alcohol" such as Isopropanol then Vodka or Gin would be better than whisky. Whichever you use, just check it on some hidden plastic before trying it on a visible location.
You could send me the 15 yo and I'll send a sample of isopropanol in exchange!
fritzthedog
Posted 03/07/2013 - 22:17 Link
Nadeem
If it is jammed - alcohol possibly will not free it (even a good quality 15 yr old malt!!). You will probably need to get a small sewing needle and gently slide it down the outside of the stuck pin in to the hole the pin sits in then gently apply pressure to the pin with the needle tip and pull it out slowly and the pin should pop out with it - you may have to do this a few times.
This has worked for me on 2 grips with the same problem - but be gentle with it - do not apply excessive pressure
Carl
Posted 04/07/2013 - 23:47 Link
Fritzdog I will attempt the sowing needle tip.
regards Nadeem
Incidentally which distillery did you say the ispropananol came from.
Jonnie Walker Green Label for Export only.
This whisky was seen abroad and rescued.
from
(Whisky Rescue Service)
