D.I.Y. K3 battery grip
Posted 03/11/2013 - 19:02
Gwyn wrote:
I've often wondered this, too Blythman wrote:
A grip can be the deciding factor between buying a camera or not. There are plenty that say their hands are too big for a non gripped Pentax DSLR, and there are others who believe the grip improves the balance with longer lenses.
I've always wondered about this argument for grips. Have peoples hands grow so much that a modern DSLR is too small for them? How did anyone ever manage to hold a film SLR and take great photos with it?A grip can be the deciding factor between buying a camera or not. There are plenty that say their hands are too big for a non gripped Pentax DSLR, and there are others who believe the grip improves the balance with longer lenses.
The notion that a grip improves the 'balance' is another thing I don't get. A lens sticking out the front of a camera is intrinsically unbalanced - that's why big lenses have tripod mounts.
And since the CG of the grip is immediately below the CG of the body, I don't see how the grip affect the balance at all.
So what do people actually mean by 'balance' in this context?
Posted 03/11/2013 - 19:27
It's very unlikely that any modifications required would be a butcher job. IOW things could be returned to normal
Posted 03/11/2013 - 19:43
This is a very strongly individual choice. 'Balance' ? - well what is meant by this I think is that if the COG is forwards (like when using a bigger / longer lens) the more surface area for your hands to make contact with the easier it is to counteract that pull and keep and good tactile sense of the camera body.
For me the grip is a permanent fixture - my senses have adapted so much to it that the K7 feels silly and unsubstantial without it. I do a lot of vertical shooting and I find it a great advantage for this, much easier to move the camera left and right with the wrist in a neutral position, and the essential buttons are right there. The additional battery options and extra power it provides is just an added bonus for me - the main thing is the solidity and extra handling finess and control it provides.
If I could have a Pentax DSLR in future that had a body size equivilent to the K7 plus grip, all in one unit with the controls and extra battery spaces included, I'd be very happy.
Posted 03/11/2013 - 22:08
I think the word "balance" is probably being misused. "stability" is a more the correct term IMO. Adding weight will add stability and lessen the chance of camera shake
Posted 03/11/2013 - 22:28
Yes, thats right, but for me its not just about keeping the camera more steady, its a dynamic aid as well. The extra contact surface with the hands helps with control in moving the camera around and in precise framing handheld. And it is very secure and quick to flick into portratit and back again with all the buttons in the same places feeling - wise.
Posted 03/11/2013 - 23:03
I felt the opposite to that. I found it easier and quicker keep my fingers on the normal controls and just rotate everything 90 deg for portrait. I never used the grip controls. interestingly observing photographers at events with grips I don't recall every seeing one of them use the grip controls in portrait mode
Posted 04/11/2013 - 07:57
I certainly don't use them, it feels unnatural
Posted 04/11/2013 - 08:15
My grips are used to house the battery with none in the camera, and a spare memory card and I never use the grips controls.
All of my cameras have grips for one reason, the whole outfit just feels better in use with a grip. I like to know that I have a big beefy camera in my hands.
One reason I'll probably not upgrade to a K-3, apart from my not believing that it delivers an upgrade in the areas of most interest to me, is the fact that I have to buy yet another grip for it, but at least it uses the same battery as the K-5 series.
If I need an upgrade I'll just chop in my K20D + grip and K-5 for a K-5 IIs. That'll save me the £200 cost of a grip.
Posted 04/11/2013 - 09:01
Nothing's changed from film slr to digital so I don't understand the reference to film SLR's.
I've always used a grip don't like holding a camera with my pinky floating free
Increased battery power is another big plus , maybe some people just dont use there cameras enough
As to balance the extra weight countered the lens front weight so when your on a gimbal you can achieve balance without pulling the camera to far backwards.
In hand is the same your supporting the lens with your left hand the less weight your body has the further forward your left hand needs to be and the less control you have over movement.
Posted 04/11/2013 - 09:08
McBrian wrote:
Doesn't work with a battery loaded in the grip
but does work with one battery in body, as mentioned AF and Green are transposed, all other functions work and it look as though the base plate profile fit is identical to the K5 series.
At a guess you don't have the grip tight enough to the mount, or the mis-fit is holding some contacts off.Doesn't work with a battery loaded in the grip
Both batteries register fine and switch over on grip depletion without issue on my k3_3rd party grip
Posted 04/11/2013 - 09:12
As you've ripped out 1 -2 locating lugs there is no going back so it is butchered.It's very unlikely that any modifications required would be a butcher job. IOW things could be returned to normal
Though the grip will still fit the K5 after so in that regards is OK.
To make it anything other than a stop gap I'd also chamfer the plastic ribs to get a better fit , then it really woudl be Butchered
The easiest way to fix the buttons is swop the plastic tops over I haven't bothered as it only a stop gap for me and having striped a grip down previously there is just to many screws for me to bother.
Posted 04/11/2013 - 09:19
Does anyone know why that pin has been removed? It seems it is a plunger and when the grip is mounted it is pressed in and doesn't fit into any holes of any sort. Therefore it should still fit on a K3 but what is its function?
CHEERS Vic.
CHEERS Vic.
Posted 04/11/2013 - 09:26
CHEERS Vic.
I think you looking in the wrong placeDoes anyone know why that pin has been removed? It seems it is a plunger and when the grip is mounted it is pressed in and doesn't fit into any holes of any sort. Therefore it should still fit on a K3 but what is its function?
CHEERS Vic.
The lug to remove is the steel pin , the reason it need removing is is a smaller diameter locating hole on the K3.
You could also drill out you K3 if you preferred
Posted 04/11/2013 - 09:49
OK. awaldram. I've just had another look and you're right. It was one of those optical illusions where things look the other way round and I thought there was a hole where there is actually a pin. Silly Me. However this makes me think? what about the other steel pin at the other end of the grip. Does this need removing also?
CHEERS Vic.
CHEERS Vic.
Lancashire
