Cooling problems
Posted 24/07/2008 - 23:11
I couldnt get the images up so have pasted the links
Pentax K7 and K5 and several black tubey things with magnifying glass in that twist around and move in and out - to be honest I am not sure exactly what I have. Will list the proper names one day..
Posted 25/07/2008 - 00:04
The links are not much of an improvement:
"Forbidden
You don't have permission to access /petes/IMGP7491 093-qpr.jpg on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
"Forbidden
Posted 25/07/2008 - 00:14 - Helpful Comment
This is IMO down to exposure. In the first image there is a nice even tone balance that will not upset metering systems and a good result is obtained.
In the second image the background is considerably brighter than the foreground and is over-exposed. This causes poor colour and with this lighting imbalance the only cure would be to light the butterfly with fill-in flash.
If shooting JPEG, setting Daylight or Cloudy as the white balance will give better results than AWB, or at least more interesting results!
Hope that helps!
Hope that helps!
Posted 25/07/2008 - 00:36
Hope that helps!
Thanks John.. I guess you managed to see the images then .. Not sure why George had a problem..This is IMO down to exposure. In the first image there is a nice even tone balance that will not upset metering systems and a good result is obtained.
Hope that helps!
I have had a look at a few other pictures with the problem and I see what you mean.. I will have a go next time i am in this lighting situation ...
Thank you for your help
Posted 25/07/2008 - 01:10
I get
Forbidden
You don't have permission to access /petes/DartmoorRider.jpg on this server.
Apache/1.3.37 Server at www.petewelsh-photography.co.uk Port 80
Forbidden
Posted 25/07/2008 - 07:51
Try refreshing the page. I can see the images, properly displayed.
Which browser are you using?
Posted 25/07/2008 - 08:30
I can't see them either, refreshed or otherwise.Try refreshing the page. I can see the images, properly displayed.
I've tried with IE6, Firefox 3, Opera 9.50 beta and Opera 9.51, all with the same error message as others have reported.
Posted 25/07/2008 - 08:49
forbidden here too, Firefox 2.
On another note, how come Johns first post on this thread is on a green background?
but it does help
but it does help
Posted 25/07/2008 - 08:54
It's what posts marked as helpful by the OP look like.
Posted 25/07/2008 - 08:55
I can't see them either, also using Firefox 2.
John's message is green because Pete has commended it as helpful.
Posted 25/07/2008 - 08:56
ChrisA wrote:
interesting feature. I might have picked a less lurid colour, but it certainly makes them stand out.
It's what posts marked as helpful by the OP look like.On another note, how come Johns first post on this thread is on a green background?
but it does help
but it does help
Posted 25/07/2008 - 08:58 - Helpful Comment
OK I have seen the photos - I went to http://www.petewelsh-photography.co.uk/petes and from there (it is a root directory) I could open the photos. I would say that John is spot on in his diagnosis.
Posted 25/07/2008 - 09:04
How strange. Now that I've visited the photos successfully using your method, the original links work for me too.OK I have seen the photos - I went to http://www.petewelsh-photography.co.uk/petes and from there (it is a root directory) I could open the photos. I would say that John is spot on in his diagnosis.
_______
Edit: though if I restart the browser and refresh the page, I'm back to the original error. Don't understand that
Plymouth UK
I have a Pentax K10d and various lenses.. When I take a photograph of a scene with a lot of green in I tend to have to "cool" it down in photoshop as they always seem to have a yellow tint to it... This happens with both RAW and JPG I have tried setting the white balance on Auto/daylight and cloudy but none seem to sort the problem The White balance seems fine to me when I take a photo of anything else... So was Looking for suggestions as to what I can do to stop this.. I guess there is something in a menu somewhere but I can't find it
I am going to try to attach two photos to this post to show the difference The first image does not seem to need "cooling"
http://www.petewelsh-photography.co.uk/petes/DartmoorRider.jpg
This next image has a lot more green in and I have the problem ... I know it is over exposed probably not in focus but that is nothing to do with the problem ..
http://www.petewelsh-photography.co.uk/petes/IMGP7491%20093-qpr.jpg
