Converting 35mm slides
Posted 21/07/2015 - 10:43
I copy B&W negatives in a similar way and have generally found the results to be far superior to those from a flatbed film scanner.
I use a remotely-triggered flash instead of an LED light and the DA 35mm macro lens. I've never found a problem with dust, it seems much less noticeable than when scanning with the flatbed.
I find I can get through them quite quickly once I get going.
12 years
Warwickshire
The theory was that once set up I could rapidly click through by placing the slides one at a time against the card strips; however I have found that the focus needs checking regularly and stray hairs and dust appear on the LightPad from the old slides so that needs checking as well; also to get accurate exposure I need to adjust the EV quite often especially if the originals were over- or under-exposed. However the results are pretty good although not as sharp as I would expect but it is difficult to see how the originals would look without a large viewer or projector. Does anyone else have any experience of this? I would add that most of the slides are 40-50 years old.
