Conker
Posted 26/08/2018 - 15:47
I thought you were going to say that rascal "PentaxExpert" had returned.
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 26/08/2018 - 15:48
It hasn't rotated by itself but has been saved in that orientation. I wonder what software was used to prepare the image? If done in Photoshop and saved in the correct orientation then it would appear as such. If it has simply been viewed in some viewer then maybe the viewer used has not saved the rotation information when the image was closed.
Posted 26/08/2018 - 16:30
Thanks, John.
I'll go back to Elements & check....
Roger.
(Don't wish that on us, Peter!!)
Roger.
Posted 26/08/2018 - 16:49
Ta-Daaa!
Thanks, John, quite right.
I had several copies on the go in Elements but decided on using this one, which was the original,straight ooc.
It was viewed in Elements, but not subject to a "Save" operation. So, although Elements revolved it for viewing, no changes were made, so it remained as-was!
I think!
Thanks for your time, it won't happen again!
Roger.
I think!
Roger.
Posted 26/08/2018 - 19:32
Looks like you need to lie down!
Then the shot should come out the right way up!
Posted 26/08/2018 - 19:58
I have been told it is camera instructions!
PU should ignore camera instructions!
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Wiltshire
Why has this revolved? By itself?
Any help would be most welcome.....
Roger.
(Same has happened in the Gallery)
