Computer problems!! PC EU virus.... :shock:
Posted 29/06/2012 - 11:09
The first thing to try would be starting in "Safe Mode" - this might get you past the virus effect. If it does, then you can try to "Restore" the computer to an earlier date - i.e. one before the virus struck.
If you have access to a second machine, you could try linking the two with a USB cable, and using an anti-virus program on the good machine to clean up the problem one.
There are standalone removal tools for this virus - I think that IF I had to use one, I would install it on a memory stick and run it from that.
If you can find some kind soul with an XP disk, you will also need the product key to go with it - and if this is already registered to them this could cause a problem with Microsoft if they are still using the original installation.
I guess that I would start by a good Google search on the virus.
Geoff
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
Posted 29/06/2012 - 11:34
Cheers Mike, I did watch that vid yesterday - it says it won't let you go into safe mode, which is why I overlooked that option and went straight into trying to locate the virus myself running Linux off a CD. However I have managed to get the computer going in safe mode so perhaps I have a slightly different variant.
Posted 29/06/2012 - 12:00
Make sure that you have/recover your Windows Serial No. for
any install.
http://www.magicaljellybean.com/keyfinder/
is reliable and safe.
any install.
Posted 29/06/2012 - 12:08
System restore didn't work so running a system scan within safe mode.
Won't a new XP disk have it's own serial number, Algi? (Hopefully I can avoid needing to reinstall but who knows!) Can't remember whether this PC came with a disk or not, or if so, where I put it
Would be tempted to upgrade to Win7 if I had to buy a new disk, but not sure if my version of Autocad (2007) would be compatible...
Posted 29/06/2012 - 12:46
A new retail disk will have a new serial number, but as long
as it's the same version of XP that you had i.e. Home, XP Pro
etc. you should be able to use the old S.No. because MS
License the CPU. I'm not sure what happens when it goes online
to register I presume that they will have a record of the CPU
serial and automatically allow it. At the worst you may have
to ring them up. The new S.No. can be saved until you need
to put XP on a new machine.
From memory I think MagicJellyBean can change the S.No. so
if all else fails and the old one won't work you can change
it to the new one.
it to the new one.
Posted 29/06/2012 - 13:15
Personally I would advise against connecting the machine to another - you might increase your problems.
I would try something like an AVG boot disk: link. You can copy it to whatever media your PC will boot from (may be CD only for an older machine).
Burn it to disk in a clean machine then set the infected one up to boot from disk in the BIOS.
But on the other hand, if your installation has been on your current machine for a while you might get a lot of other benefit with a clean install.
Do be aware though that some clever viruses hide themselves in the MBR so even that won't help!
Posted 29/06/2012 - 13:18
This any help? Tells you how to remove manually.
http://www.deletevirus.net/police-central-e-crime-unit-virus/
Posted 29/06/2012 - 13:25
Can you download and install malwarebytes, then check for updates and install them. Then boot into safe mode, and run a full scan. This should find and delete the virus.
Gary
Gary
Armed with a K3, some M, A, FA, DA, and star lens. With an eye open for "just one more lens".
My PPG link
My PPG link
Posted 29/06/2012 - 13:33
For info on this virus and it's removal got to
link
and follow the instructions.
A good antivirus/spyware/malware suite is the Comodo Internet Security and
System Cleaner suite of programs and they're free.
hope this helps
regards
Will
link
hope this helps
regards
Will
The first and the simplest emotion which we discover in the human mind is Curiosity.
Edmund Burke
Edmund Burke
Posted 29/06/2012 - 13:55
When I tried to access this on the office pc, TREND MICRO's security warning flagged this as a DANGEROUS SITE. Access it at your own risk!!
Posted 29/06/2012 - 14:26
steven9761 wrote:
Possibly because of the referance to viruses. I checked it out on my PC/Kaspersky anti-virus before I posted and nothing was flagged, but, agree this could be a double-bluff! Doesn't appear to be though, and I accessed it via a US Police site.
When I tried to access this on the office pc, TREND MICRO's security warning flagged this as a DANGEROUS SITE. Access it at your own risk!!This any help? Tells you how to remove manually.
Posted 29/06/2012 - 14:32
I remember years ago, in the age of 1.44Mb floppy disks, I has a "magic bullet" disk for such eventualities. However, try as I might, I cannot find anything remotely similar for downloading onto a usb stick or memory card!!
Nottingham
For people who haven't heard of it, the PC EU virus loads a banner purporting to be from the police, claiming that your computer has been connected with illegal activities and requesting you pay a £100 fine or have your computer seized.
I can get into my C drive by starting the computer in Ubuntu, but can't locate the offending file myself. Has anyone had any experience of tracking it down? Otherwise I will just transfer my files and photos onto an external hard drive, and obtain a Windows CD to reinstall XP. (I don't suppose anyone has an old WIndows XP disk lying around do they? .....:wink
