Clarity
Posted 23/12/2011 - 11:04
Comon guys....no ideas out there?????
Posted 23/12/2011 - 11:09
I'm not really sure what you mean.
The clarity slider in PSE ACR adds "punch" to your picture.
Posted 23/12/2011 - 11:44
Nor me!I'm not really sure what you mean.
Unless the OP is asking if there's a similar adjustment in PSE *after* you've opened the image. But I have no idea what he means by 'soft option'.
I think people are usually very willing to answer questions, but if the question isn't clear, it's not easy to answer.Comon guys....no ideas out there?????
[quote="Gwyn"]
The clarity slider in PSE ACR adds "punch" to your picture.[/quote]Does anyone know what it actually does, though?
Visually, it seems to make it look a little clearer - but not actually sharper. In fact I can sometimes get a sharper image eventually if I reduce the Clarity setting to less then 0, and then bring the contrast and sharpness up after opening the image up.
So I'd guess it's some manipulation of contrast, but quite what it does (or why it needs a separate control for it), I don't understand at all.
Posted 23/12/2011 - 13:04
I read the question as 'does anyone know if there is a way within elements to soften a picture, (say) when taking portraits when this might provide a more pleasing result, to an otherwise 'sharp' image. Although I could be wrong, and I don't know if this is possible within elements either.
Posted 23/12/2011 - 14:00
Once you go into the PSE editor it is possible to soften a photo, but afaik not in PSE ACR - Clarity is set to 0 and can only make things clearer - hence the name .
Posted 23/12/2011 - 14:05
Mike-P wrote:
My pictures are normally soft anyway so I have never needed it
mine too .
Posted 23/12/2011 - 14:53
Clarity, Vibrance and Saturation are all sliders with +/- 100 available in the ACR that comes with CS5. Also Elements 9 I think, though I haven't installed that on the new 'puter yet, so can't confirm..
Posted 23/12/2011 - 16:22
Mike-P wrote:
Just checked my Elements 9 (again) and yes it is +/-Also Elements 9 I think, though I haven't installed that on the new 'puter yet, so can't confirm..
Makes the OP's question seem even odder though.
Posted 23/12/2011 - 21:32
Sorry guys, I havent made myself very clear at all. I do apologise. I thought i would bring up a subject that other people would be interested in, but instead.... Basically what the questions is, in photoshop elements 8 you can reduce the clarity setting when opening a RAW file, to soften images for portraits and typical wedding shots that are so popular, however if you have taken a shot in JPEG and want to achieve the same results how would you go by doing so. Does that make sense to anyone
Posted 23/12/2011 - 22:22
Well you could open it in ACR and play with the clarity.
Not near my PSE at the me to try and remember how to do it in the editor but there are several ways.
One which springs to mind is a duplicate layer, Gaussian blur and change of blending mode and/or opacity.
