Camera advice.
Posted 11/10/2022 - 09:09
The K5 is still a good camera and, using a simple adapter, will accept your M42 lenses. The best adapter to buy is the Pentax Adapter K, which you attach to an M42 lens. Then bayonet this onto the camera. When you change lenses, just unscrew the lens and screw another one on, the process having effectively turned the K5 into a screw thread camera. The adapter can be removed from the camera when you want to use a bayonet mount lens.
The adapter has no electronics, so the lens will need to be stopped down manually. Focus at open aperture, stop down the lens to the working aperture you want and then press the shutter release. If the lens has an auto/manual lever, then that can be used to open the lens up to open aperture and then close it down again, thus saving using the aperture ring all the time. This works well if, for example, you want to set f/8 and aperture priority. One click to open up for focusing, click the lever back again to close down to shoot the picture.
Posted 11/10/2022 - 09:45
I am selling a K5 with a genuine Pentax grip.
View it here
I have also used a Sigma 500mm Mirror lens on a K Ring thread adaptor. It works great.
View it here
Posted 11/10/2022 - 09:59
The K5 is still a good camera and many swear by the image quality from that 16MP sensor. The only thing I'd mention is that I believe the K-5 does not have focus peaking, whereby the areas with highest contrast (and therefore most in focus) are highlighted in a specific colour in live-view. For that you'd need to spend a bit more for a K-3, but if you only plan to use the optical viewfinder then it won't matter.
For full-frame on a limited budget you could look for a used Canon 6D or Sony A7, they're the cheapest FF options and both would work with M42 lenses.
If the budget allows you could consider the Pentax K-1. The Pentax Adapter K works as with the K-5, but the K-1 is Full Frame to match the m42 lenses
Barrie - Too Old To Die Young
Posted 11/10/2022 - 13:06
Thank You for the great comments, Very helpful.
4 years
