Blue tint on 50mm
Pietrach
Posted 20/04/2012 - 10:30 Link
Hi
I got a Pentax 50mm 1.7 M lens. When used in M mode (did not try other) with auto white balance and no exposure compensation it underexposes by approx 0.75-1 stop. The worst thing is that it produces a blue tint which looks like the WB was off. Even weirder thing is that when shot deep in the room it is underexposed but with normal colours, but when by the window then the whole photo goes blue.There was ambient light only with no artificial lighting.
When I set the exposure compensation to +1 then exposure is correct and the blue tint disappears.
Any ideas?
Algernon
Posted 20/04/2012 - 12:54 Link
Did you buy it off a magician!
Try setting a manual WB such as daylight, also metering at about
f/5.6... lower values on M lenses are usually off.
With any lens you should always take metered shots at every
aperture of a white or grey card to see which ones expose
correctly.
JAK
Posted 20/04/2012 - 13:37 Link
Metering with M lenses seems to work better with the K-5 than it did with older bodies. They've only just got it right!
You haven't said which camera body you are using or how you set about setting the exposure, or what it is you were taking so really there are too many variables. It seems though you got it sussed by using the exposure compensation setting so what other ideas are you after?
John
Pietrach
Posted 20/04/2012 - 13:47 Link
I am using k20 and meter using green button.
I was looking if someone else had the same problem. As is, I cannot take purposely underexposed photograph without a blue tint :/
JAK
Posted 20/04/2012 - 14:48 Link
Try taking a general shot outdoors in the sunshine and see if that helps for starters to make a comparison.
What happens setting the camera to Av with the lens wide open, is that OK?
Why it should have a blue cast, no idea unless something was causing a colour shift, like light bouncing off a blue wall?
You did say the blue tint disappeared when the exposure was correct.
I expect it is something you'll have to get to know its strange behaviour and make allowances for unless it was a one-off.
I've found that with pre K-5 cameras, the metering with M lenses using the green button was unreliable apart from at full aperture, but just try with a K-5, wow! At last they've got it right.
John
davidstorm
Posted 20/04/2012 - 22:54 Link
I agree with John. I have quite a few old manual lenses and they work brilliantly on the K-5, no need for any exposure adjustment normally. The K-x is not bad, but requires about 0.5 to 1 stop under-exposure to get it right. I haven't noticed any blue tint or any other colour tint, regardless of exposure, although a lot of the old lenses do add warmth to various degrees.
prsjnb
Posted 21/04/2012 - 10:36 Link
JAK wrote:
Metering with M lenses seems to work better with the K-5 than it did with older bodies. John
Seconded!
One of the least expected but most welcomed improvements of the K5 when compared with the K20D or the K10's 'blood brother' the Samsung GX-10. Makes the K5 a worthy investment for this reason alone if one has, or is intending to acquire, a collection K or M lenses.
Jon
