Blue bands with GX20
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
i would return it. alot of people have had this problem with the samsung and pentax,
Chris
Is this an inherent fault and I've just failed to notice it sooner?
Cedric
If the sensor is one of the famous S--Y flops (produced down to a price)and it sounds a bit like it send it back.
Cedric
shim
Sorry you've lost me there - aren't they all the same in GX20s and K20Ds?
I've sent the camera back to the retailer today - just have to see what they suggest as a fix. Having said that, given the option, I don't know whether to get it replaced with another GX20 or, bearing in mind the suggestion that a good number of GX20s/K20Ds suffer the same problem, go for something else entirely as I'm not too tied into any system yet?
Thing is, what to go for; I've been a bit spoilt by the bang-for-your-buck that Samsung/Pentax give you and I don't think there's anything out there for the same money (c£650), that comes close?
Suggestions/advice welcomed!
Chris
I have a Samsung GX20 and have recently noticed that some of the shots taken at ISO 1600 have a faint blue band at the top and bottom of the frame. It's only noticeable in darker shots, where the band is visible as it passes over mid-tones but it runs right across the frame, top and bottom. I've gone through some of my older shots and it does appear in shots taken at ISO 1250 but it has only recently got so bad that it is noticeable without specifically looking for it. To give you an idea - If I was using a film camera, I would swear it was a light leak.
Anyone any ideas?
The camera's still in warranty; should I return it as faulty? Has anyone else suffered this problem?
Chris
