pentax verses samsuns software
Posted 17/05/2009 - 22:56
I havent tried it m8 but i would be 99% sure the software would work as the samsung GX10 and Pentax K10D are one in the same.
Posted 18/05/2009 - 00:33
I'm sure it would msuds as they both shoot DNG's but never tried so not a 100%.
Also there might be a software update on the samsung site.
Posted 18/05/2009 - 02:30
Good luck, as for me I use the Windows COPY and PASTE, then copy again to a DVD and then close the section of the disk and then work on in LIGHTROOM and would love to know the answer.i
Posted 18/05/2009 - 07:47
Just put the SD Card in a Reader and copy to HD with Windows Explorer.
You could drag the whole folder over and then rename it to whatever the photos are about.
shim
shim
Posted 18/05/2009 - 08:13
I'm with shim on this. Copying/moving the folder to your HD is easier with card reader than through a cable.
Once on the HD I use Elements 4 for my tweaking/ converting.
Cheers, HG
PPG entries.
PPG entries.
Posted 18/05/2009 - 08:18
shim
shim
I agree it's the best way I find.
Tel,
Posted 18/05/2009 - 08:30
I always download raw images into picassa, its quick and easy, once in there close picassa and open your Samsung raw converter (ver 2.0 download available from Samsungs web site) click file and then select open folder D in the drop down menu and select the folder you require.
Oh and forget about the Digimax editing software, mine kept on freezing/crashing as well, so I got rid of it and bought PSP.
Posted 18/05/2009 - 19:08
Interesting. I used it for a several months until I bought Photoshop with ACR and experienced no problems at all.
I didn't like it particularly, mind you.
suds
