Birds In Flight
Posted 09/05/2009 - 13:57
PentaxBabe wrote:
![Comment Image]()
[/img]]http://www.photoanswers.co.uk/Gallery/Detail/?msItemId=110567![Comment Image]()
Not sure if I have done this correctly. Hopefully you will see my picture! This is my best picture of a European Roller in flight. Taken in Tanzania 2009 while watching and trying to photograph them mobbing some Lesser Kestrels. I had actually given up as I didn't believe I would actually manage to get a shot at all. Suggestion for taking birds flying at high speed gratefully accepted. If the link to the photo doesn't work I will add the picture to the main gallery tomorrow.
See this LINK on how to post photos.[/img]]http://www.photoanswers.co.uk/Gallery/Detail/?msItemId=110567
Wonderful coloured bird well captured, but the image is lacking contrast I feel.
Posted 09/05/2009 - 14:06
I can't do a great job on a small compressed image, but I'd suggest you up the contrast a little & also try cropping tighter top & left (moving subjects are generally best framed with more space to move into)
I hope you don't mind but I've quickly knocked up an example, it can be removed if you wish.
[IMG]http://i134.photobucket.com/albums/q105/RR76/European-Rollercopy.jpg[/IMG]
Regards, Bob
Regards, Bob
Posted 09/05/2009 - 14:52
hope you dont mind,
[IMG]http://i727.photobucket.com/albums/ww272/scottthehat/European-Roller.jpg[/IMG]
Posted 10/05/2009 - 09:59
No of course I don't mind. I just don't know how to do what you have yet but I will have a go. I was just amazed that I even managed to get a fair clear Roller in the shot. They were all over the place. By the time I had managed to get them in frame on the camera it was just a matter of shotting and hoping for the best. I took over 100 shots and most are blurred or don't even have a bird in the picture!
Thanks again for your suggestions wil practise in Paintshop Pro.
Jeanette
Jeanette
Posted 12/05/2009 - 19:57
http://www.flickr.com/photos/pentaxbabe/3526331560/
Second attempt at trying to post a picture on he gallery!
Jeanette
Posted 12/05/2009 - 20:10
Choose Image from bar below and paste the flickr details you have above
between the centre brackets ][ Press enter for line feed to leave space above picture
It's not worked here because the link you have given above is to your webpage...... you need the link/url of the actual photograph.
shim
shim
Posted 12/05/2009 - 20:28
[img]
[/img]
Thanks Shim,
if this hasn't wrked I give up
As u can tell I am nt very techie
[/img]
Thanks Shim,
Posted 12/05/2009 - 20:37
It's not worked because you are still just posting the website address
For a photo it has to be an address with .jpg on the end.
The one you did above finished with "European-Roller.jpg" on the end i.e. the name of the file. You need to logon to your page and it should let you copy the link to the photo with .jpg on the end.
Better luck next time.
shim
shim
Posted 14/05/2009 - 19:41
Hooray!
Have you got a bigger version, it looks a nice photo.
Posted 14/05/2009 - 19:42
you got there, like the shot a little p and p, would make this better,but i still like it well taken, nice feeling of speed,
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 14/05/2009 - 19:53
See I told you I wasn't very techie! It only took me ......
Sorry, no that is the original photo, so its as large as it gets.
I know I am really thick but what is p and p?
Posted 14/05/2009 - 20:00
PP for me means 'post-processing'. Get the image on your comp' and go to work on it like tweakin' the contrast, saturation and curve levels, and maybe some croppin' etc.
Posted 14/05/2009 - 20:02
It's a nice shot... the thorns and background are perfect.
I think Scott meant PP which stands for post processing or editing
to you and me. Like RR and Scott did on your earlier post.
shim
shim
Chesterfield Derbyshire
