Beware - SR induced shake - Oops!
Posted 01/07/2012 - 21:16
I've done it the other way round SR 28mm.... Lens 400mm
Posted 01/07/2012 - 23:20
28mm setting for a 400mm lens is the "correct" way to make the error though - the other way round would have the camera adding excess correction! Must have been worrying for a bit John!
Naturally I've, um, never made this mistake. Nope.
Definitely not.
After the third time...
Definitely not.
Posted 08/08/2012 - 00:03
Just got a K-5, very impressed so far. Am I right in thinking that if I use A-series 35mm lenses (which I do), then when I turn the camera on and it asks for a focal length, I put in the nominal length plus 50% rather than the straight value, in the same way that my 50/1.7 turns into a 75mm on digital?
Thanks all.
Thanks all.
K-3II - HD DA20-40 Limited, HD DA55-300PLM, SMC DA10-17 Fishy, AF201FG Flashy
Posted 08/08/2012 - 00:17
Thanks all.
Your 50mm/1.7 is still 50mm whether it's on a film camera, a digital camera, or whatever the film or sensor format is.
Thanks all.
Posted 08/08/2012 - 08:03
Many thanks for the feedback. Looking forward to getting to grips with the K-5.
Posted 08/08/2012 - 22:58
What do you put in for focal length with say a 1.5x converter? DO you add the additional 50%. Also any changes for extension tubes?
Posted 08/08/2012 - 23:27
You enter the focal length of the lens multiplied by the converter magnification. 28mm x 1.5x T/C = 42mm.What do you put in for focal length with say a 1.5x converter? DO you add the additional 50%. Also any changes for extension tubes?
I'm not sure how you would work out the change in focal length, if any, when using extension tubes.
Posted 09/08/2012 - 10:44
If you're using the shutter speed = focal length rule do you include the 1.5 crop factor in the calculation
Barrie - Too Old To Die Young
Posted 09/08/2012 - 14:56
Barrie's question is answered in the instruction manual, and refers to the slowest "safe" shutter speed when hand holding.
For a 35mm film camera this is taken as the reciprocal of focal length, so for a 200mm lens that would be 1/200sec. For an APS-C DSLR it would be 1/300sec (200mm x 1.5 = 300mm.
When entering an SR figure for a lens, just use the actual focal length.
Logically, when using say a 2x converter you would presumably use 200 x 2 = 400mm as the starting point, although I have never actually tried that myself.
Posted 09/08/2012 - 17:29
If a converter has all the electrical contacts it just passes
the lens FL straight through.... so basically your stuck with
that... It seems to work though.
With a basic TC you can enter the FL so you can allow for the TC.
Posted 14/08/2012 - 08:36
Mike-P wrote:
Oh, that's bad!!
You only need one, can't see the point in getting any more.Looking forward to getting to grips with the K-5.
Lancashire
Then I realised my focal length had been set to 500mm yesterday and I hadn't changed it - oops...
