Bembridge Windmill, C&C please
MarkD
Posted 29/08/2009 - 22:36 Link
Took these on a recent visit to the Isle of Wight. Still learning how to use the 12-24. At the wide end it seems to be a case of when you think you're too close, take another step! Took the first one for the shadow but now I don't feel it has the impact I was expecting. Perhaps because you can't see the sails so it isn't obvious what it is. ( Though that's often a good thing!) Should I have gone a little wider?
The second one I took with a polarizer (you can see the edges of it on the colour version, oops) but I think I prefer the B&W version.
Any thoughts on these?
.........all the gear, no idea!
Me super, MX, LX, K5,DA 18-55WR, DA 17-70, DA 55-300, DA40 Ltd, FA50 1.4, Samsung D-Xenon 12-24,Samsung 100mm macro M50 1.7(x3), M28 3.5, M35 2.8, M100macro f4, M135 3.5(+others)
bforbes
Posted 29/08/2009 - 23:20 Link
I prefer colour so it's number three for me. I'm also interested in the fact the filter shows. I've just taken delivery of the same lens and would normally fit a UV or skylight filter to it. Is any filter going to show up as your polarizer did or is it because a polarizer is deeper than a normal filter.
Father Ted
Posted 29/08/2009 - 23:23 Link
Number two for me.
RR
Posted 29/08/2009 - 23:27 Link
I like the colour version also & like the perspective distortion from the wide angle. Can you not remove the vignette in Post processing or during raw conversion Mark ?
The first shots's shadows under the roof are a little too deep for me & a little distracting. It may be from your mono conversion as I notice there is some detail in the shadows of the colour shot that is gone in the mono equivalent.
MarkD
Posted 30/08/2009 - 00:33 Link
RR, there is a a bit more detail under the roof but I wanted the high contrast look. (The colour version of number 1 looks fairly flat and boring to be honest)
I suppose I could play about with these with a bit of fill or selective HDR but I don't do much post processing as I haven't really got the time ( or experience if I'm honest). Same reason I haven't fixed the corners of the colour one yet. Thats why the B&W is slightly cropped - it's quicker!
I think the whispy clouds in the B&W number 2 are what do it for me. It just puts a bit more interest in the top left compared to the colour one.
Barrie, I think it's just that the polarizer is almost twice as thick as the normal filter so it shows in the corners at 12mm. I don't have a UV filter for this lens yet but some people do recommend buying the (expensive) ultra thin type, others say it isn't necessary. But the front element does stick out a long way so I'll feel happier when the UV filter turns up.
I think going a bit wider on the left of number one would have helped.
Thanks for looking.
Edited by MarkD: 30/08/2009 - 00:40
aminstar
Posted 30/08/2009 - 04:05 Link
One and three for me look great, although I do like the second one too, but definitely the colour version tops up. The vignetting spoils it a little but the image looks really great
Technoblurb
Posted 30/08/2009 - 08:30 Link
Second & Third one for me. I really like the distorted image against the blue sky especially in black and white. For me, the crop it too harsh on the fist image.
goggalee
Posted 30/08/2009 - 08:46 Link
I like all of them, nicely captured!
Pentax K10D, *istDS
Pentax 18-55mm,50-200mm,Macro 100mm
Takumar-A 28-80mm, Sigma 170-500mm, Soligor Teleconverter x2
Finally!! Sigma 10-20mm
God, grant me the serenity to accept the things I cannot change, courage to change the things I can, and wisdom to know the difference.
https://pentaxphotogallery.com/maliskaoosthuizen
Aiki
Posted 30/08/2009 - 18:51 Link
The first catces my eye. But I would crop some bottom away. So the shadow will be better exposed and balancing the pic.
Aiki
Pentax K20D; SMC DA 18-55mm II kit; Sigma AF 70-300/4-5.6 APO DG MACRO
GIMP Flickr
MarkD
Posted 30/08/2009 - 21:37 Link
Thanks Aiki. That does help balance the picture.
But.... after looking at it again it looks even less like a windmill that it did before.
I guess this teaches me to take a wider insurance shot after my attempt at "artistic framing" so I can reframe or crop it differently when I get it home and realise I've messed up again.....
Thordell
Posted 30/08/2009 - 21:45 Link
Although I usually prefer colour I find myself drawn to number one, love the texture and the slightly menacing feel of the sail shadow.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
thoughton
Posted 31/08/2009 - 01:57 Link
3rd one for me. I like the black sky in the top right on the 2nd pic, but the sky is already such a nice deep blue it looks great in colour as well. And I also really like the colour of the windmill, so the 3rd one wins it for me
I want to like the 1st one but as you mentioned I think with a bit more sail it would be better. Also the sky in the 1st shot looks a bit washed out.
Tim
FlickrFluidrPPGStreetPortfolio site
Edited by thoughton: 31/08/2009 - 01:59
Lance B
Posted 31/08/2009 - 02:20 Link
Thanks for looking.
This is my favourite. I like it alot!
I also like this one:
Cameras:K-7/K20D/*ist D/K10D
Lenses:DA14 f2.8, A16 f2.8, FA20 f2.8, FA31 f1.8, DA35 f2.8 macro, FA43 f1.9, FA50 f1.4, A50 f1.4, A50 f1.2, FA50 f2.8 macro, DA*55 f1.4, FA77 f1.8, DFA100 f2.8 macro, A100 f2.8, DA*300 f4, FA*300 f4.5, DA10-17 FE, DA12-24 f4, DA*16-50 f2.8, DA17-70 f4, FA*28-70 f2.8, DA*50-135 f2.8, DA*60-250 f4, FA*80-200 f2.8.
Flashes:AF540FGZ, AF360FGZ
Karl
Posted 31/08/2009 - 04:24 Link
No 2 by far and away the best. Dynamic composition with the sails, shadow and the mill it's self. Great detail in the sky with lot's of contrast. Highlight and shadow detail just right for me.
Put this side by side with the colour shot and the colour one looks like a RAW start image and nothing more to me.
https://pentaxphotogallery.com" target="_blank">https://pentaxphotogallery.com/images/black_link_small.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Aiki
Posted 31/08/2009 - 10:32 Link
It dependes on taste I do not care about "not looking like windmill".
For me it works - it IS windmill !. And I like the shadow
Aiki
GIMP Flickr
