Beginners pentax k-m question
Posted 07/11/2009 - 02:25 Link
Hi we've just gone the DSLR route and bought a k-m we have two digital lenses the kit lens and a 50-200mm lens.
We have also got a couple of k fitting older lenses from ebay, obviously dating from the film days, these do fit but the camera won't take pics won't give an f reading, is there anything we can do with settings etc to use these lenses or just put it down as experience and stick to lenses for the k-m.
one is a macro lens and the other a 100-300mm lens.
Thanks for any help Don & Brandy
JudithAnn
Posted 07/11/2009 - 04:17 Link
Hi Don...
Go into menu....then go to "c" ,page three, scroll down to 19.aperture ring, press ok, then click permitted..number "2" will come...keep that stting by clicking on menu.
That should do it.
I own a K-m and have used manual lens from my K1000, that I bought 100 years ago or so...
Feel free to check out my gallery here on the sight...all photo's are from the K-m....it is a small camera with big abilities!
Edited by JudithAnn: 07/11/2009 - 04:18
iceblinker
Posted 07/11/2009 - 10:31 Link
After setting "Permitted"...
If no "A" setting on the lens, the f number doesn't appear because the camera doesn't know what the lens is set to, and can't control the aperture, due to lack of electrical contacts.
You can either use the lens with the largest aperture only in Av mode, or all apertures in M mode. With M mode, press the Green button to set the appropriate shutter speed. This doesn't always work well so some manual compensation may be required.
~Pete
Posted 08/11/2009 - 00:52 Link
thanks guys, wife tried Judith Ann's suggestion and it worked fine.
