Autumn at Llanystumdwy
Posted 01/12/2018 - 21:56
Yeah I thought the same with the processing. Last one for me has the best composition
Posted 02/12/2018 - 22:50
Minimal processing, all single images @ f16 (or abouts).
Adrian
Adrian
K5IIs, Sigma 10-20, Pentax DA 16-85, Pentax DA 55-300, Pentax 70 Ltd, Metz 44 AF-2.
Flickr: https://www.flickr.com/photos/ambott/
Posted 03/12/2018 - 04:39
Oh my God! What a great set! I loved all the pictures. Wonderful job. Keep it up!
Posted 03/12/2018 - 07:56
Likewise, I thought some type of hdr, no exif data, but looking at the bright sunshine, and slow shutter speed , you were probably using a filter or lens was stopped right down, might be diffraction causing it ?
Looking at your Flickr stream, I've not seen any others look like this.
I'm not knocking your set, btw, good shooting
Posted 04/12/2018 - 00:46
The shutter speeds varied between 1/8" to 20s, and all were taken using a CPL.
The only difference to previous sets is the camera, first images I have posted with the K3.
Cheers all.
Adrian
Cheers all.
Adrian
Posted 04/12/2018 - 00:58
K3 is a very good camera,
I wonder If it's the shooting parameters that need changing, working your way through the menu, might be worth checking, as this look is not at all what we are used to seeing from your shots.
You shooting raw or jpeg, if jpeg, what quality is selected ?
Again, I'm not knocking your shots, just feel they are a little off, compared to your usual style.
Derek
Derek
Posted 04/12/2018 - 05:09
Amazing collections. All the images are beautifully captured. I loved nature's photography.
Posted 05/12/2018 - 02:00
Derek
All RAW, Derek, processed in Lightroom.K3 is a very good camera,
Derek
Previously I would take all shots handheld, so for example the ISO in this particular set would be high; again I don't know if this would make a difference?
Unfortunately I cannot post a RAW file here so that you could see what one looked like.
A few similar examples from a local wood, similar shooting conditions
Regards all
Adrian
Posted 05/12/2018 - 07:24
What was the WB setting?
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 05/12/2018 - 21:50
Camera set to AWB, all images also set likewise in Lightroom.What was the WB setting?
AB
Posted 05/12/2018 - 22:50
Hi Adrian, I suppose I should ask, do you think there is something just a tad "off" with the images.
If you don't, then there's no need to continue this.
If you do, I'd try a total reset on the camera, and restore it to factory settings.
Might well be worth a shot.
Derek.
Derek.
Posted 06/12/2018 - 07:12
I wonder if it is the Custom Image setting, it is easy to inadvertently change this whilst fumbling around. On mine it is set to Natural so the images in RAW are flat and any changes are made in Lightroom. As others have said, these are really nice.
If that is the case you can read the settings on the camera and correct them precisely in post. I had to do this after a dark shoot which all had Bleach Bypass applied!
Posted 08/12/2018 - 03:58
Amazing images. What beautiful images you have captured! Loved it.
North Wales,
UK
All K3, 1-4 DA 55-300, rest 16-85.
1
2
3
4
5
6
7
8
Adrian
