any advice
Posted 31/07/2009 - 12:20
If you like landscape and architeture shots i would recommend one of these, 12-24 for sale
I have one and cant recommend them high enough (and the current list price is now over £800 too for a pentax branded one!! making these samsung ones great value)
Bodies: GX20 | MZ-3 | MZ-M | Auto 110 complete kit
Primes: DA*300 F4 | DA40 F2.8 Ltd. | SMC-A 50/1.7 | Sigma 30mm F1.4 | Sirius 28/2.8
Macro : SMC-A Dental 100 macro
Zooms: 12-24 SA | 18-55 SA | 50-200 SA | 28-80 FA | 35-80 F | Vivitar 28-200
Other: Bellows | Tube sets | Vivitar 2x PK/A Tele | SEF-36PZF Flash | SBG-D1V Grip | Billingham 335
My Flickr
My Flickr
Posted 31/07/2009 - 12:47
hello thankyou i just been looking on srs website could you please tell me what all the codes mean i no a/f is auto focus but i not to bothered about that but was looking on manual focus and they all different some say A M K would these fit my samsung GX10 thankyou
Emma
"Photography is a way of feeling, of touching, of loving. What you have caught on film is captured forever... it remembers little things, long after you have forgotten everything." Aaron Siskind
Bodies K20D, LTL 3, K1000d
Lenses Pentax 50mm, Pentax 135mm, Tamron 70-300 macro
Posted 31/07/2009 - 13:42
Hello
I assume from what you have said that you have a Pentax Digital SLR and the 18-55 and 50-200 kit lenses. These 2 lenses are of reasonable optical quality and should cover most of what you want to do. They are ok for most landscapes, architecture and portraits.
For landscape and architecture you may wish to upgrade your current 18-55 lens to a 10-20 or 12-24 or 16-45 lens, which would give you a much wider angle of view.
The Sigma 50mm macro is good for close range macro photographs, but a 100mm macro lens would enable you to work at a further distance from the subject.
For wildlife photography you probably would require a 300mm lens. If you upgraded the 50-200 lens to a Pentax 55-300 or a Pentax 80-320 lens, then these would cover quite a lot of wildlife photographs. For ultimate quality in this range a Pentax DA 300 is very good. Obviously for wildlife at a greater distance, then 400mm and 500mm are required.
Pentax manual lenses:
K Lenses require you to set the aperture on the lens. This requires an aperture ring enable in the camera custom settings and the will only work correctly in M mode on the camera.
M Lenses require you to set the aperture on the lens. This requires an aperture ring enable in the camera custom settings and the will only work correctly in M mode on the camera.
A Lenses have an A setting on the aperture ring; if you select this then apertures can be selected on the camera and you can use all camera programme modes. However, if you use the aperture ring then you must perform the set-up the same as for K and M lenses.
You mention a 28mm lens, however, your current 18-55 kit lens is not a bad performer at 28mm.
Friendly Regards
Graham
Graham
Posted 31/07/2009 - 14:51
thankyou for your advice i am tempted to get the tamron 70-300mm macro from srs only 79 quid i really would like the 100mm macro or equavilant but cant find it cheap enough
Emma
Barking,
Essex
thankyou emma
