AF on K-7 Vs K20D
Posted 14/03/2010 - 23:51
The only time I have focusing problems with my K20D is when light and/or contrast are low. In such situations, the K-7 is improved, especially under tungsten/artificial lights.
Posted 15/03/2010 - 14:38
I've just been doing some comparisons between my K20D and a K-7 and found no significant differences, even in low light (before the focus assist light on the K-7 come on).
What lenses have the issue? If they are screw drive, the symptom can often be caused by backlash in the drive system, and depending which direction the rotation is coming from, you can get a different focus point.
Another thing to bear in mind is that the AF points have a much wider coverage than just the focus dot coverage and if you have several objects at different distances in the AF point area (especially with a wide angle lens) the AF cannot decide which object to focus on and either focusses on the wrong one or gives up completely.
Posted 15/03/2010 - 23:12
A mix I am afraid Richard
The ones it really happens on are as follows:-
SMC-DA* 50-135 F2.8
Sigma 24-70mm F2.8
Tokina 20-35mm F2.8
Plus, very occasionally
SMC-FA 50mm F1.4
Sigma 105mm Macro
Sigma 55-200mm DC
Like I said, it is not all the time, but only on occasion, but when it happens it is not good, especially as you only have one chance to take the image.
Strange though, my 16-45 has never had the problem (touch wood) only the ones stated, and it varies between close and general focus.
The only body that never does it, is the istDS but 6MP is not what I need for these instances.
Hmmmm, a strange one.
SMC-DA* 50-135 F2.8
Sigma 24-70mm F2.8
Tokina 20-35mm F2.8
SMC-FA 50mm F1.4
Sigma 105mm Macro
Sigma 55-200mm DC
Some Cameras
Posted 16/03/2010 - 09:58
Well, my k20 needed some AF adjust, and went hunting in low-light... It also had a specific problem with my tamron 70-200 2.8 where it couldn't snap out of close focus : once there, it just did a little focus move on each half-press, but nothing else... I had to either switch to MF, or focus on something nearby, to make it responsive again...
Now, I noticed that the focus sensors are tricky... The center point, for instance, is in fact extending well below the red square, and if what you're focusing onto has a more "contrasty" edge in this area, then that's where it will focus...
The K7 is generally faster (test done with two FA50, focused at the same time), much more responsive in low-light, and locks faster (less hunting around).
It needed no AF adjust, but the sensors are still tricky!
Posted 16/03/2010 - 18:19
Sorry Guys,
No real help as I am just intending to buy a K7................
Paul
Paul
K5's (2)both gripped, K10d gripped, Pentax 28-90 f3.5, Sigma 18-250mm, Sigma 150-500mm. Sigma 105mm f/2.8 EX DG Macro, Sigma 10-20 f.4-5.6.EX DC, Hoya 135 f2.8, Take on 28mm f2.8 Pentax AF360 flash, 2 fill in slaves. 30 metre remote release, Rt angle viewfinder, Giotto NOT 3261B Tripod with Manfrotto 808Rd4 ball head, Manfroto 4861RC2 monopoly, shoulder stock, various filters etc, Panasonic SET HBS HD Video cam, Tamrac Explorer 8x backpack and a sore back.....
Photography is an index for measuring futility and pride.......
Paul
:wink
http://s743.photobucket.com/home/pg20_photos/index
https://www.flickr.com/photos/pg20
Paul
:wink
Posted 16/03/2010 - 18:24
A second thought is to 'clean' the contacts. I have noticed that this does improve the Af function on both my K10 bodies.
Seconds to do.
Paul
Seconds to do.
Paul
Paul
:wink
Paul
:wink
Posted 16/03/2010 - 22:28
Don't know if I really see any difference, but there was really quite a lot of dirt coming of the contacts. I just took a cotton swab with some alcohol to clean them.
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
UK
Is the AF on the K-7 better than the K20D?
I ask as I have intermittent problems with the AF on the K20D. It does not matter which lens is on, but having said that it is only 3 that really have the problem. I have used the AF adjust but to no avail. Having said that, sometimes the lens is spot on, others it is way out. No problems though with the lenses on the DS, but still very occasional issues on the K10D.
So My question is, the K-7, is it more reliable? Please only answer if you have or used both a lot.
