Macro tubes help please
andyvarney
Posted 17/03/2010 - 09:39 Link
I have just bought a set of Jessops tubes with the electrical contacts off eBay for £20 which seemed like a bargain?
Now, when I switch on the camera (K20D) it asks me to input the focal length. Is this the length of the tube I have attached plus the lens length?
Eg if I use a 50mm lens and a 13mm tube is the focal length 63mm?
Also does anyone else use these tubes with K20D and offer any hints?
Hope you can help.
Andy
It's not the size of the dog in the fight, but the size of the fight in the dog!
gartmore
Posted 17/03/2010 - 10:12 Link
We've had a few discussions in the past about Jessops extension tubes and the consensus was that they work better if you scratch off some of the black paint on the tubes to create another contact.
You input the focal length of the lens you are using. A 50mm is remains a 50mm lens, its just focussing closer.
Unlocker
Posted 17/03/2010 - 11:54 Link
Yup, £20 is a bargain!
Scratching the paint off is what solved my problems here, with pics!
andyvarney
Posted 17/03/2010 - 16:15 Link
That's just so helpful thank you all, I would never have guessed that in a million years.
What a great place this forum is!
Andy
andyvarney
Posted 17/03/2010 - 16:22 Link
The only thing I have noticed is that I only have 6 contacts on my tubes
gartmore
Posted 17/03/2010 - 18:22 Link
I have a set and a K20, you dont get focal length information but the scratching, I think just creates anothe contact to the mount itself. You'll need to do a search but I think Mannesty was the original brains behind this.
Anvh
Posted 17/03/2010 - 18:49 Link
Bojidar Dimitrov has the answer.
Most likely you don't have a Digital info contact.
The KAF mount features the same six electric contacts as the KA, and thus remains fully compatible with the older mounts. However, in addition to those (electric) contacts, it features a seventh — electronic one. Using a yet-unknown serial protocol, the body uses this contact to communicate with a digital chip contained inside the lens housing. The chip provides at least the following information:
- Focal length of the lens. This allows more efficient flash operation as well as calculating the longest hand-holdable shutter speed. In addition, it is also one of the parameters taken into account when the body is in one of the "smart" picture modes and has to choose a program curve. Prime lenses provide one fixed value, while zooms provide an approximate value that changes as the focal length changes. The focal length information is precise enough to distinguish between 35, 28 and 24 mm lenses, as evidenced by F-flashes that trigger a warning when they cannot cover the field of view of the lens.
- Lens-to-subject distance. This is used by the more advanced bodies for calculating if the flash is powerful enough to illuminate the subject that is in focus. In addition, this is one of the parameters taken into account when the body is in one of the "smart" picture modes and has to choose a program curve.
Exact selected aperture. The KA mount supports displaying the picture-taking aperture when the "A" aperture setting is engaged. The KAF mount supports displaying the aperture even when a numeric f-stop is selected. The displayed value is quantized by half-stops, but is correct even when a variable-aperture zoom lens is used.
- Lens dimensions. The lens also gives the body enough information for determining if the lens is going to cast a shadow on the subject when the camera's built-in flash is used. This parameter takes into account the size changes due to zooming and focusing too.
The lenses contain a ROM chip that holds the program curve (brightness/shutter speed/aperture) for prime lenses or up to three program curves for zooms at their different focal length settings. The distance information is hardwired on the lens barrel. A number of tiny parallel conducting/non-conducting strips are glued to the rotating part of the lens. The same number of contacts are attached to the fixed part of the lens. As the lens barrel turns during focusing, different combinations of the strips are detected by the contacts. There are four parallel strips in the F 50/1.7, resulting in at most 16 different distance settings. But for that particular lens not all combinations are used.
A similar technique must be used for the focal length.
For the full read link
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 17/03/2010 - 18:49
andyvarney
Posted 18/03/2010 - 09:36 Link
Thanks for all your help. My tubes don't even seem the same as those above.
I have added a couple of pictures below of the contacts.
[IMG]http://img.photobucket.com/albums/v48/avarney/PENTAX%20FORUM%20PICS/DSCF2197.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v48/avarney/PENTAX%20FORUM%20PICS/DSCF2198.jpg[/IMG]
Does that ring any bells with anyone?
Andy
Anvh
Posted 18/03/2010 - 15:33 Link
Andy you need the turn them around the top is the bottom
The screw in the left here is the same as
The screw as the lower screw in the middle of the Flange.
So the one you're missing is the Digital info contact, on the right side of the arrow.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 18/03/2010 - 15:34
fatspider
Posted 18/03/2010 - 15:51 Link
Ken is perfectly correct, and it was me that was having the problem which Peter (mannesty) sorted out, its an old post though
Look Here link
And those tubes weren't a bargain, they were a steal
My PPG link
My Flckr link
