AF Calibration charts
Posted 25/04/2013 - 21:10
None. I did try some of them but it's quite simple just to aim at an angle on the back of a corn flakes pack or something with text on at max aperture and adjust until focus is correct.
Posted 25/04/2013 - 21:13
is this wide open or shut down? Sorry but I'm still learning to lingo.None. I did try some of them but it's quite simple just to aim at an angle on the back of a corn flakes pack or something with text on at max aperture and adjust until focus is correct.
Will
Pentax K-x, DAL f3.5-5.6 18-55mm,Pentax-A 50mm f2, DAL f4-5.6 50-200mm, FG360FGZ
Posted 25/04/2013 - 22:38
Yup by max aperture I mean wide open.
Posted 26/04/2013 - 08:34
Thanks for the clarification
Will
Will
Posted 26/04/2013 - 11:49
Thought I didn't have a problem but have just tried that and ascertained my DFA 100mm macro was back focussing by quite a bit. Have adjusted it to +5.None. I did try some of them but it's quite simple just to aim at an angle on the back of a corn flakes pack or something with text on at max aperture and adjust until focus is correct.
Then tried my 50mm FA f2.8 Macro and it is spot on without needing any adjustment!
What I cannot understand is that if the focus looks correct in the viewfinder, why isn't it what you get? Also how can different lenses vary in their fine AF adjustment requirements? This seems to be at odds with the whole SLR concept. I don't recall any talk of this issue back in the film camera days.
Posted 26/04/2013 - 14:29
I'll have to try it with the old lenses I was using then and see how they fare. Obviously no facility to correct them if they do need it!
Posted 26/04/2013 - 16:28
sbrads wrote:
I found this AF chart the best as there's no ambiguity about what is being focused on. Print out the single pages near the end of the pdf.
These are the charts I've used for a couple of years.I found this AF chart the best as there's no ambiguity about what is being focused on. Print out the single pages near the end of the pdf.
All good information, but he makes no mention of how to setup a zoom lens for checking. Should it be set to the short end, long end, or somewhere in between? Who knows?
Posted 26/04/2013 - 17:27
When using these test charts do you focus from the minimum focus distance of the lens you're testing or is there a set distance for the chart being used?
Or does it not matter?
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 26/04/2013 - 17:29
Thanks for that link. I'm sure there is some good info there but the rough and ready cornflake packet serves the same function - the one I have has a word search on the back and that's just great!
What I am failing to grasp is how some lenses can focus OK on the viewing screen yet be out of focus on the sensor and hence need adjustment, but not others. I always use the centre point or focussing and check it visually as I would a manual lens so that is consistent.
I've just rechecked the adjusted 100mm DFA macro with the camera in manual focus mode and the adjustment I made holds good.
An explanation would be interesting and useful. If it was a camera issue and all the autofocus adjustments were consistent I'd understand, but that is not the case.
Posted 26/04/2013 - 17:37
Anyone come across/use Focus Tune software?
Posted 26/04/2013 - 17:40
yes there is - just use the overall adjustment. You've just got to remember to reset it when changing back to other lenses.
13 years
There are plenty of charts around - but which one do you all prefer?
