Cleaning?
Posted 26/04/2013 - 17:34
Roger - if it's "oily" fingermarks and the like, I use the little alcohol wipes similar to those used in hospitals, prior to insertion of a syringe. They contain isopropyl alcohol, which will dissolve the oily film, but evaporate without damaging the screen. Alternatively, you could just use a damp, soapy cloth, drying off immediately to prevent further build-up of residue.
Posted 26/04/2013 - 18:09
Alcohols also denature plastics and make them brittle.
Posted 26/04/2013 - 18:39
That'll be the soapy cloth, then....
Thanks Steven & John.
Roger.
Roger.
Posted 27/04/2013 - 10:55
Sensor cleaning swabs & solutions probably work OK as well -> clean the sensor and then the rear screen (or lenses/filters - they work well for these as well).
OTOH, you could always fit a phono screen protector which can then be replaced when it gets too bad.
Posted 27/04/2013 - 18:56
Saliva and bog roll here
Waits for the predictable "I'm not buying you're 2nd hand cameras" comments - hee hee
Wiltshire
Thanks,
Roger.
