Switch-on noise
Posted 26/04/2013 - 21:15
I think your camera is also known as a K-m (same beast) and if so the noise you are hearing is the sensor shake mechanism which is intended to dislodge dust particles from the sensor on start-up. It can be switched off in the menu, but there's no point in doing this.
Just leave it as it is and don't worry!
Posted 26/04/2013 - 22:02
yup that's sensor shaking to knock of any dust.
More modern cams like the K-5 ( and probably the K-30 ) use a more ultrasonic type shaking on startup which IMO works better
Posted 26/04/2013 - 23:14
The K30 still has a variation on the old "brrrrr" sounding sensor cleaning system unlike the K5's silent whisper of (dust) death
Everything Changes
https://www.flickr.com/photos/arleimages/
Posted 26/04/2013 - 23:38
Excellent - that's solved the mystery. Thanks
13 years
Argyll
One issue I'd like to ask opinion on if I may - when I switch on the K2000 there is an immediate chattering noise, sort of like 3 or 4 drumbeats in a row) with associated vibration. This happens with any lens fitted.
The family also has a Nikon DSLR which makes no such noise. Is there a problem with the K2000 which I should have addressed?
advice appreciated.......
cheers
