A PENTAX K-1000 FROM THE U.S?
Posted 14/02/2004 - 01:22
Hi Kida,
Check out this link
http://www.aohc.it/slr03e.htm
This gives the major differences in names between the cameras sold in the states to the ones here. Basically there is no difference other than the name. However, the later K1000 had some of their housings replaced by plastic and are not as good as the earlier 2 types. If you check the photo links above you will see that the Mk3 version didn't have the "ASAHI" above the word Pentax on the pentaprism. My advice would be to avoid one of these but otherwise you should have no problems. Good luck
Kim
Check out this link
Kim
Posted 14/02/2004 - 18:55
Thats some pretty damn cool info,
Thanks alot Kim
Thanks alot Kim
24 years
Thanks for your help,
Ben.
