51mm Filters
MX veteran
Posted 06/12/2007 - 00:35 Link
I have a very nice Cosinon 135mm manual focus lens which is I use for macro when used with extension tubes. It has 51mm thread size and I cannot get a protective filter anywhere in this size. I have also looked for a step up ring but no luck there either!
Does anyone know if this odd size is still available?
I would be interested to know if anyone else has come across a lens using this sized filter.
K100D Super, 18-55, 50-200, Sigma 10-20, Sigma 70mm macro and lots of old lenses
Posted 06/12/2007 - 07:59 Link
Are you absolutely sure it is 51mm? This tends to be a push-on size for lens caps. It is almost unheard of for a manual focus 135mm lens to be anything other than a 49mm or 52mm fuilter thread. 51mm is sometimes the outside diameter and the inside filter thread would be 49mm.
Kim C
Posted 06/12/2007 - 10:47 Link
If it really is 51mm (and I agree with John on this, unlikely) about the only solution would be a custom one made by SRB but it would be £'s
Kim
MX veteran
Posted 06/12/2007 - 12:30 Link
49mm is too small and 52mm too big! I could try clingfilm????????
Kim C
Posted 06/12/2007 - 12:45 Link
Cheap soft focus filter.
My only other thought is that it might be a Series thread, probably Series VII.
Kim
