Yongnuo speedlight 560 ii
melness
Posted 28/10/2014 - 20:22 Link
Hi,i went to take some shot of our newly groomed westies tonight stuck the flash on and it wouldn't fire on the camera at all ,soon as it was off the camera and set on S1 off camera it fired up no problem .I put the flash back on camera and still it wouldn't fire . Am i missing something or is the flash faulty ....
Sean
stub
Posted 28/10/2014 - 21:21 Link
Sounds like you have the shutter speed above 1/180th. The Yongnuo 560ii is a very reliable unit. Make sure you have the one contact point in the right place on the hotshoe. Put it in M mode..
Stuart..
Jonathan-Mac
Posted 29/10/2014 - 08:51 Link
I often knock the camera off 1/160s and that causes the flash to not trigger.
melness
Posted 29/10/2014 - 10:25 Link
Hi,what do you mean by knock the camera at 1/160s
Sean
McGregNi
Posted 29/10/2014 - 13:10 Link
Or even 'knock the camera off 1/160th' ... I would also like to know what exactly that means. I thought anyway, even in M camera exposure mode, it wasn't possible to set speeds higher than 180th unless the flash is set to HSS (assuming it has that feature) ?
Edited by McGregNi: 29/10/2014 - 13:11
DoctorJeff
Posted 29/10/2014 - 15:13 Link
Have you tried putting the camera mode dial to X?
X on my K20 defaults to 1/180th and f8 (with the f8 being variable while the shutter speed is fixed. Switch to M and tth flash will not fire.
Geoff
X-5
istDS
K2000
P50.
melness
Posted 29/10/2014 - 16:16 Link
Geoff
Will try tonight many thanks
Sean
Sean
melness
Posted 29/10/2014 - 18:40 Link
Right......eh .....
My problemo with the flash is this ........ (note to self) TRY PUTTING FLASH ON THE RIGHT WAY .....there i've said it .....
Embarrassed doesn't come close ....
Sean
Sean
DoctorJeff
Posted 29/10/2014 - 21:55 Link
And, when most people have stopped laughing (except me ) it should be remembered that the metal plate on the Yongnuo that fits into the flash mount on the body, has two corners chamfered off - and these are at the back.
Logically, these should be at the front to assist in mounting the flash, but for some strange oriental reason Yongnuo do it differently.
It is still great value for the money, though.
Geoff
X-5
istDS
K2000
P50.
melness
Posted 26/11/2014 - 07:26 Link
Is 180 the max shutter speed I can achieve. Just bought a cheap off camera triggers was hoping I'd be able to get higher speed. Any advice welcome
Sean
Sean
