Yongnuo RF602 as a remote shutter trigger...?
Posted 10/02/2019 - 21:36
No need to reply. Sorted it out now and got it firing... Would delete the message if
I could...!!
I could...!!
Stuart..
Stuart..
Posted 10/02/2019 - 22:38
Just in case it helps anyone with a similar problem, how did you solve it Stuart?
Posted 10/02/2019 - 23:14
Oh ok... I had earlier watched a you tube video where they were remotely firing a Nikon camera. I thought thats not a bad idea. You get far more range than the little Pentax remote trigger. But in the video they connected the Yongnuo receiver to what looked like a sync socket. So I was being a bit thick (Some on here would say im always thick...lol) And connected the lead from the Yongnuo receiver to the X-sync socket on the K1. receiver was getting the message but no shutter release.. Then the penny dropped. The lead from the receiver should be connected to the remote Jack socket. Changed it over and, hey presto.. all worked perfectly. Lens auto focused with a half press and shutter fired with a full press.. I used the RF603 units but it will also work with the RF602 unit or a combination of.. Also does not matter if they are Canon or Nikon model triggers.
Obviously the trigger unit will be in TX mode and the receiver will be in TRX mode in order to work..
Stuart..
Stuart..
Posted 10/02/2019 - 23:26
That's great, thanks Stuart, it could save somebody being in that frustrating position where something should work but stubbornly doesn't! There's usually a simple reason....
Posted 10/02/2019 - 23:39
And if all else fails.... Read the instruction manual of course...
Just found this...!! I actually connected my lead to the sync socket on the Yongnuo unit.. As I didn't have a 2,5 jack each end to hand. Seems to give the same outcome.
Stuart..
Stuart..
Manchester
Stuart..
