yashica to pk converter
neilr
Posted 13/08/2011 - 20:22 Link
hi all has anyone seen any converters for the yashica lens to pk fit.
i have some yashica kit from a couple of my old 35mm cameras.
cheers Neil.
womble
Posted 13/08/2011 - 21:22 Link
I don't think you can and keep infinity focus as the registration distance is different.
If anyone makes one, SRB Griturn will.
K.
Dangermouse
Sad to say I doubt they exist, at least for sensible money and without glass which tends to degrade image quality.
The only adapters I see are for the M42 screw mount lenses, as this mount is small enough to fit inside the K mount and therefore allows an adapter which won't affect the distance from lens to sensor. If the lens is held too far forward you won't get infinity focus, making it a bit useless!
petrochemist
Posted 13/08/2011 - 23:00 Link
I assume you mean the Contax/Yashica (registration distance 45.5mm) rather than the rarer Yashica Pentamatic, Pentamatic II (registration distance 43mm).
As others have already said infinity is likely to be a problem unless the CY mount fits inside a PK (~0.04mm is not much to play with but even that's better than -2.6mm...)
It would be possible to get the mounts on the lenses changed, or to convert a teleconverter but it's unlikely to be worth the effort.
For macro work several bellows take interchangeable lens mounts allowing a vast range of lenses/bodies to be connected together in just about any combination. I believe BPM also do a shorter connector for these mounts that does away with the need for the bellows (but still gives effectively an extension tube).
T2 (& adaptal 2) adapters are also very common, and I've also used a m39/PK adapter (for enlarger lenses) though that was with bellows/extension (My helicoid doesn't go out far enough to reach infinity focus with one of them). Various medium format adapters are also available.
The only adapter with a glass element I've seen is to mount Nikon lenses - but my only Nikor is M39 anyway
neilr
Posted 14/08/2011 - 08:50 Link
thanks for the replies thought it was a long shot. will just sell on my old yashica lens so at least someone may get some use out of them.
cheers Neil
Edited by neilr: 14/08/2011 - 09:29
Algernon
Posted 14/08/2011 - 10:17 Link
You need to give more details. Some C/Y bayonets can be altered
with Dremel. There were two C/Y bayonets identified by the colours
on the aperture ring. Leitax also do an adapter for about 70 Euros.
If it's 42mm screw thread you need a flanged adapter off ebay.
petrochemist
Posted 14/08/2011 - 10:38 Link
Found this which might help:
How to convert Yashica/Contax to M42 mount
kingfisher
Posted 14/08/2011 - 22:27 Link
try Leitax .....i converted Contax/Yashica lenses with it, and it worked perfectly
