Windsurfing Swan
Posted 09/05/2009 - 19:19
Nice shot Dave.
shim
shim
Posted 09/05/2009 - 19:31
Okay never seen they do that before
Posted 09/05/2009 - 19:40
that's the territorial aggression move... the male will flare out the feathers and put its head and neck back and move in a series of fast bursts towards the 'intruder' swan (or goose). you'll often see the parent do this to the cygnets at the end of winter to clear the area for the next breeding season.
if that move doesn't work the male with then 'fly' at the other bird, running across the water and flapping as if to take-off. if the other bird doesn't fly off it will be attacked and bitten. i've seen fights last hours - interrupted by time-outs to preen.
saying all that, they are very gentle birds and i've never had a problem with them - apart from causing exposure problems with photographs!
Pentax k1000, MX, ME Super, K5iiD 18-55, Tamron 70-300, Tamron 500 mirror, pentax 10-17, 50 1:4, a manual 28, some extension tubes and a bagful of memory cards. That's all i need... and a load of film cameras too... that's it, honest.
Posted 09/05/2009 - 19:49
Many years ago, my wife and I were in what could be best described as a motorised punt on the River Cam, in Cambridgeshire. The punt had an outboard motor that was white and not unlike a swan in appearance. We were attacked by a male swan just like Dave's excellent photo above so we just lay flat on the 'floor' of the vessel, opened the throttle and made a quick exit!!
Thanks also Dave for the info about the new reserve, must have a look. BTW any Avocets?
Andrew.
Posted 09/05/2009 - 20:45
Stunning image Dave, can't see much in the way of blown highlights either! Very good.
What lens did you use?
By the way, I see, from your signature, that you own a DA*50-150! Should that be a 50-135? It's my favourite lens by some margin, though the 16-50 is becomming my most used!
Flash: Metz 58, Metz 48
Posted 09/05/2009 - 21:39
That is a great shot - in the right place at the right time and making the most of it.
On a dark desert highway, cool Pentax K5 in my hand.
My Kit
K5 & 18-55 Kit lens, K7, Pentax 18-250mm lens, Sigma 10-20mm lens, Sigma 105mm Macro lens, Pentax 50mm 1.7 lens, Cokin P Series Filters
My Kit
Posted 10/05/2009 - 15:49
By the way, I see, from your signature, that you own a DA*50-150! Should that be a 50-135? It's my favorite lens by some margin, though the 16-50 is becoming my most used!
I used my Sigma 120-400mm HSM at 400mm, aperture priority, f8, 1/1600s, iso200.Stunning image Dave, can't see much in the way of blown highlights either! Very good.
Yes it a DA* 50-135mm.
I don't think it was an aggressive move as it was just being blown across the lagoon with no other birds on its course.
The older I get the faster I was.
Dave
K-3 II, K10D, DA16-85, DA*50-135, DA12-24, DA18-55, DA 50, Sigma EX DG 70mm Macro, Sigma 70-300mm, Sigma DG 120-400mm APO HSM.
Metz 58 AF-1.
My Flickr link
Dave
Metz 58 AF-1.
My Flickr link
Frampton,Lincs
Dave
Metz 58 AF-1.
My Flickr link
