Winder Me II problem
Posted 26/03/2011 - 22:12
I had one which did this, but stopped when I turned it off, connected it to a camera, then turned it back on again.
It could be that the contacts on the base of the camera need cleaning? Most M series bodies have never had a winder fitted so the contacts filled with 25 years of gunk, which now prevents the camera and winder from communicating.
Posted 26/03/2011 - 22:16
Hi Matt,
Tks for the suggestion, I will try to clean them and try again, I will let you know of the outcome,
Posted 27/03/2011 - 15:55
I find a cotton bud dipped in lens cleaning fluid (or the spray you can buy to clean computer screens) works pretty well. It's gentle enough not to damage plastics or paint but will loosen dirt enough to remove it.
Posted 29/03/2011 - 07:37
Dear Matt,
I had to open it as one of the 4 metal contacts close to Pentax plate was stuck, cleaned and fixed it but nothing changed so I opened the top,
where the triger is and cleaned all the blue oxid, it now works on continuos function but not on single frame, I think it won' t get much better!
Posted 29/03/2011 - 10:48
Try turning the selector switch back and forth repeatedly, as this sounds like gungy contacts.
I've evidently been very lucky in finding winders (have two ME IIs and an MX) which weren't abused or neglected!
Posted 29/03/2011 - 12:49
Hi Matt,
Yes, I already did but it works on C and I don' t have a heavy finger!!!
I started wit an Sp 1000 almost 40 years ago and then changed to an Me super that is stilll with me, meanwhile I have bought a bit around and
have 2 more Me super and winders for all...I am back to analog and will
start developing films again soon!
Many tks for the support and help.
Helder
Helder
Posted 29/03/2011 - 13:29
The good part is that the winders aren't expensive to replace if needed. I've seen them for £10 in working order before now (hence my having two - thought a spare worth having at that price).
Posted 29/03/2011 - 20:35
Hi Matt,
You' re right, I have 3 bodies and 3 winders, just the last one had this problem...mauybe it is wise to buy another one!
Helder
Helder
Portugal
I have a winder Me II that when you put it on c or s it won' t stop shooting it is always on I had the same problem some years back with the first Me winder but no solution, any ideas on how to fix it??
Help apreciated
Antpaubarcar
