Will this fit my K5
Posted 02/06/2011 - 19:31 Link
Hi everyone. Will the lens in the link below fit my K-5??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370511751285&ssPageName=ADM...
PPGlink
Pentax K-5 with 18-50mm & 50-200mm Kit Lenses, Pentax 55mm f1.4 SMC DA* SDM Lens, Pentax DA 12-24mm , Pentax DA 35mm macro, Pentax SMC FA 77mm Limited, Pentax SMC FA 43mm Ltd, Pentax SMC F 50mm, Sigma 24-70mm, Metz 58 af-2
Pentaxophile
Posted 02/06/2011 - 19:33 Link
Should do, and it'll be fully functional (except for focus) if you put it on the A setting.
Posted 02/06/2011 - 19:48 Link
Ok I might be thick. Already have it and when I put it on I get a flashing F--- on the screen.
PPGlink
Pentaxophile
Posted 02/06/2011 - 19:51 Link
Is the aperture ring set to A?
Posted 02/06/2011 - 19:56 Link
Ah didn't look at that. Will check it when I get back.
PPGlink
SteveEveritt
Posted 02/06/2011 - 21:44 Link
Also make sure Enable Aperture Ring is on in your cameras menu
Mannesty
Posted 02/06/2011 - 23:16 Link
This is only required when using lenses that have no 'A' setting on the aperture ring.
If the lens used has the 'A' setting and you prefer setting the aperture on the camera body, there is no need to enable this custom setting.
If you use the lens's aperture ring to set the aperture, and this custom setting is not enabled, the shutter will not fire.
Posted 03/06/2011 - 07:06 Link
Took all your advice and it works fine. Thank you.
PPGlink
