Where do I start
Posted 23/06/2008 - 19:31
The 50 - 200 Pentax DA is a useful companion to the 18-55 and quite cheap these days
Posted 23/06/2008 - 21:02
Telephoto zooms with "macro" settings probably won't provide the kind of magnification and close-focusing you're thinking of.
For real close-up photography, you need either a dedicated macro lens, or an accessory such as an extension tube set that would be good to use with an old second-hand lens such as a Pentax-A 50mm F1.7 or Pentax-M 100mm F2.8.
So I suggest choosing whichever telephoto lens you think you would like best for telephoto photgraphy, and think about macro afterwards, separately.
Tamron 70-300mm LD Di is very good for price. Pentax 55-300 should be better but is a lot more expensive. Alternatively, the Pentax 50-200 is nice when travelling light.
~Pete
Posted 23/06/2008 - 21:23
Thanks for your replies.I think I will start with the Pentax 55-300 and try to research and source a used lens for close up stuff.I am sure the A640 will do until then.Looks like I am on my way to Watford at the weekend.Thanks again.
Posted 24/06/2008 - 13:09
Close focussing ability on a long zoom is nice for those moments when you're looking for eagles with the long lens and a butterfly lands in a flower in front of you. It's no substitute for a true macro lens.
The 55-300 will actually get you close enough for things like butterflys, and it's sharp enough at 300 to allow some cropping while you save for a proper macro lens.
but it does help
but it does help
Posted 24/06/2008 - 16:40
F2.8.
You do of course mean either the Pentax "M" 100mm F4 or "A" 100mm F2.8.
F2.8.
Posted 24/06/2008 - 18:08
I have the Tamron 70/300 and it's well worth the money imo got some great shots with it.
Posted 24/06/2008 - 19:54
I've used those super-zooms with "macro" suffixed to the end of their names. Nothing wrong with them I suppose, and until recently I thought they did a great job. But if you want to do Macro, there is no substitute for a real macro lens (never tried extension tubes, perhaps as good??).
Anyway, the point is that I was shocked at the quality of the images I could get with a macro lens even though the focal length was far under the zoom+macro lenses I was used to.
Just tossing in another vote/suggestion to go for a true macro solution later on.
FYI, you might want to look at the Tamron 90mm f2.8 Macro lens when the time comes. From what I've seen, the quality is up there with the Pentax 100mm but can be found for a couple of hundred dollars less than the Pentax. I am exceptionally pleased with the Tamron macro lens.
Posted 24/06/2008 - 23:00
No, I did mean Pentax-M 100mm F2.8 - and use it with extension tubes. I suggested this as a low-budget alternative to a macro lens.
You do of course mean either the Pentax "M" 100mm F4 or "A" 100mm F2.8.Telephoto zooms with "macro" settings probably won't provide the kind of magnification and close-focusing you're thinking of.
~Pete
Posted 25/06/2008 - 16:47
I have the Cosina/Vivitar 100mm f/3.5 macro, which is plastic and lightweight (270g), small enough to forget about and takes fine shots at 1:2 (1:1 with included adapter which I don't use). This is one of my default "out for a walk" lenses.
Example shot. Click on this for all my photos tagged with that lens:
Also obtained the Vivitar Series 1 105mm f/2.5 macro, which is metal and weighs far more (656g). Bigger too. But very sharp and magnifies to 1:1. This is the macro I use when I have the luxury, but I did not take it on holidays. (Though next time I might.)
I would heartily recommend either of these.
I have also reversed a 28mm lens on the kit, for super-magnification. Pretty well impossible to control except in studio with macro rails etc. So not for me.
South London
cam and it is lovely.Many thanks,any pointers would be very nice but please remember I will not understand the difference between the letter designations for lenses yet,though am very willing to learn.Many thanks.
