When centre focussing doesn't quite work
Posted 13/06/2008 - 07:56
If they're not sharp, then it may well be that the boats had moved towards you enough to throw them out of focus.
If it is this, then it would be a good application of Quick-Shift on the lenses that have it.If they're not sharp, then it may well be that the boats had moved towards you enough to throw them out of focus.
It would take a bit of practice, but turning the focus-ring a fraction during the reframing after the initial lock would allow for such movement.
Posted 13/06/2008 - 08:04
Would it not be possible to use one of the off centre focus points and zone focussing. Set the focus to the place where you want the boats to be (quite how you do that I am not too sure about as there's nothing much to focus on), set the off centre focus point on and wait until it lights up to confirm focus and shoot?
Posted 13/06/2008 - 08:12
In theory yes.Would it not be possible to use one of the off centre focus points and zone focussing. Set the focus to the place where you want the boats to be (quite how you do that I am not too sure about as there's nothing much to focus on), set the off centre focus point on and wait until it lights up to confirm focus and shoot?
In practice, have you ever actually tried to change the focus point while trying to frame a picture of a moving target?
I suppose if they were going straight for a long time, and you knew that you wanted the boats in a particular part of the frame, then it might be possible.
But both of those are big ifs.
Posted 13/06/2008 - 08:38
I agree but yes at a motorcycle event I was able to predict the approximate path some bikes at least would take and I used that technique with varying success - but as all the shots were rubbish it didn't make much real difference
Posted 13/06/2008 - 13:24
I'd thought about this too - but would be way too fiddly! Easiest thing when I go there next time I think will be to have the lens slightly wider so that I can aim at the centre of the boat and get the shot without having to reframe. Then just crop the bit of extra sky or whatever out in LR.
Very much an amateur.
Posted 13/06/2008 - 14:29
I've got some sporting events to cover this month.
It's video stuff, car racing on a dirt oval track.
I'll be shooting some stills also.
for my first trial run I'll have my k10's (50mm 1.4 and 100mm 2.8 macro) set up to shoot jpegs, with continous shooting, af-c, and auto select af points. and also some on manual focus.
that last point (letting the camera choose it's af points rather than my usual center af point) is where I think you'll find your solution for "Missing the Boat" so to speak....I'll let you know how I make out!
Posted 13/06/2008 - 21:28
The image I posted is a crop, probably just over a 1/3 of the orginal (shot landscape).
Since the pic is a crop, couldn't you have just focussed on one boat and then re-centre by cropping afterwards?The image I posted is a crop, probably just over a 1/3 of the orginal (shot landscape).
I sympathise with you. A month ago I went to a motor race meeting and failed to get a single good shot from panning. I had lots of shots of the middle and back end of the cars <g>. The best shots I got was when a car hit the gravel and I was able to take photos of the tow truck pulling it out!
Richard
Pentax K100D
DA 18-55 kit lens
A50/1.7 A28/2.8 M50/1.4 M135/3.5 A70-210/4
DA 18-55 kit lens
Posted 13/06/2008 - 23:06
Richard
It's not the end of the world by any means, the sailing lake is a 5minute walk from where I live, and with the long summer evenings there are plenty of opportunities to improve my technique
Richard
20 years
Billericay,
Essex
Dan
