what macro lens??
Posted 19/10/2010 - 18:04
Think you may struggle with this, remember the 1.7 only gives af within limits, you will still have to roughly focus the lens manually, even on my DFA100 Macro I have to manually pre-focus. If the manual lens does not have quick shift(unlikely) you will have problems.
Davex.
Davex.
Posted 19/10/2010 - 18:14
Why so?If the manual lens does not have quick shift(unlikely) you will have problems.
You can always MF the lens on-top of the 1.7x AF TC right?
Posted 19/10/2010 - 18:48
Indeed so Stefan, i was thinking about manually focusing an af lens, which of course would not apply here. You can always MF the lens on-top of the 1.7x AF TC right
Davex.
Posted 19/10/2010 - 19:04
Don't get an M42 macro lens. You won't be able to see anything through the viewfinder when you try and use it on a small aperture (as you often will with macro).
Tim
Posted 20/10/2010 - 06:32
chaude wrote:
I'm interested in making a dive into macro photography, and being an owner of a 1.7x AF TC I'm thinking about getting a manual lens and use it with the AF adapter to get autofocus...
Just very confused about which one to get, or even a M42 lens + mount??!!
Probably looking at the cheap end at the moment...
Gasp! Forget the 1.7TC, that's a telephoto instrument, not a macro tool. (unless intending to remove the glass, just to gain the not-necessary AF coupling ability for use as an extension tube, but that would be heresy - unless the TC is optically crap and already worthless as a TC.)I'm interested in making a dive into macro photography, and being an owner of a 1.7x AF TC I'm thinking about getting a manual lens and use it with the AF adapter to get autofocus...
Anyway; I found this old discussion on this forum via Google, see if it covers your needs:
https://www.pentaxuser.com/forum/topic/close-up-lenses-vs--extension-tubes-vs-ma...
Also there's some helpful basics re understanding some of the important technicals of macro, in these three sample pages on the topic that are out there in the ether:
http://www.cambridgeincolour.com/tutorials/macro-extension-tubes-closeup.htm
http://www.cambridgeincolour.com/tutorials/macro-lenses.htm
http://www.nikonlinks.com/unklbil/macro_adapter.htm
Oh and welcome to macro photography, it's a fascinating field that has consumed most of my off and on camera life for decades.
.R.
Posted 20/10/2010 - 10:38
That's not true, TC can be used to increase the macro capabilities of a lens.Gasp! Forget the 1.7TC, that's a telephoto instrument, not a macro tool. (unless intending to remove the glass, just to gain the not-necessary AF coupling ability for use as an extension tube, but that would be heresy - unless the TC is optically crap and already worthless as a TC.)
The TC multiplies the focal length but it leaves the minimum focus distance alone so with a 1.7x TC you can magnify 1.7x more then without one.
I've used a 2x TC to get 1:2 magnification with the DFA100
Posted 20/10/2010 - 11:50
Thanks, interesting stuff. Do you have refs to any math on that? I've never seen any and was of the belief that a TC is only an AoV reducer (ala the tele family), not a magnifying optic.Hypocorism wrote:
And telephotos cannot and do not 'magnify' (unless illusions [of perspective] are allowed to count - or until someone finds a way to put all 3476 km of the moon at 1:1 on my sensor -- or should I say an exact APS-C size R.L part of it in full detail, when taken from terra firma? but you know what I mean).
Btw: The D.FA 100 (both models) already do 1:1 so dropping it to 0.5x is a significant downgrade.
I hope you really meant 2:1 there (double real life size)?
If the latter then that would surely make it a real option, although tubes/bellows/rev... can all do that and more too, but sans the AF.
Also, what is the clarity of the images you produced with a TC combo? Do they stand as "pure" crisp-sharp under critical scrutiny, or are they of a soft (artificial expanded) look?
.R.
Posted 21/10/2010 - 13:07
Hypocorism wrote:
--8< snips--
.R.
Thanks, interesting stuff. Do you have refs to any math on that? I've never seen any and was of the belief that a TC is only an AoV reducer (ala the tele family), not a magnifying optic.That's not true, TC can be used to increase the macro capabilities of a lens.
--8< snips--
.R.
Great. I've now confirmed that a TC works for this, ref some articles:
http://en.wikipedia.org/wiki/Macro_photography
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=000wE8
http://www.tonywublog.com/20090109/using-teleconverters-for-macro.html
The main extra downside (as opposed to non-optics methods like ext.tubes), appears to be that eg., a 2x extender introduces decreased (image) resolution by a factor of 2, as mentioned here:
http://en.wikipedia.org/wiki/Teleconverter
But that's a subjective matter and one that could well be acceptable to the O.P here, considering they already own a TC anyway.
Thanks to Anvh for correcting me on this matter.
.R.
Posted 21/10/2010 - 13:14
You already figure it out.
Indeed it's 2:1 with the macro lens
Posted 21/10/2010 - 13:48
Yes when someone types something like that out character of, I just dyslexia assume. You already figure it out.
.R.
Whitehaven,
Cumbria
Thanks for the help!!
