What first flashgun?
Garnett
Posted 19/06/2012 - 11:22 Link
I'm wondering about trying out a flashgun.
I've been doing abit of reading and the Yongnuo 560 seems well regarded and very good bang-for-buck. It's also very reasonable. my budget's limited.
My issue is that it is manual. I suspect I'd want to try an auto first before I try and start inputting settings manually.
I can't find a decent budget auto flash with tilt and swivel that fits Pentax cameras.
I'd love to have some input from more experienced forumites on what I should go for.
~Pentax K-5, DA 18-55mm f/3.5-5.6 AL WR, DA 35mm f/2.4 AL, DA 55-300mm f4.0-5.8 ED, FA 50mm f/1.4, M 50mm f/1.8 - flickr
wvbarnes
Posted 19/06/2012 - 11:46 Link
I use the Sigma EF 610 DG ST, it's excellent and very easy to use. Full PTTL on all modes, handy low power 7 degrees down for macro if you can't (like me) afford a ring flash yet|! 1/180th max sync speed though. Takes Canon sized cheap pattern diffusers too.
sterretje
Posted 19/06/2012 - 13:20 Link
There might be an issue getting the Yongnuo to work on a K5. There have been a couple of post about that on pentaxforums (and possibly elsewhere).
There is an easy fix for it (if you can handle a solder iron) by modifying the flash hardware, but if one wants to do that with a new flash is another question.
http://www.pentaxforums.com/forums/pentax-k-5/162331-mounted-yn-560-flash-proble...
Edited by sterretje: 19/06/2012 - 13:24
Garnett
Posted 19/06/2012 - 13:28 Link
Thanks WVB and Sterretje. I'm fairly happy with a soldering iron, but not so happy with Manual flash at the moment - I think starting out an auto flash might ease me in to things a bit. Whether or not I can rationalise the resultant doubling in necessary budget (from £50 for the Yongnuo to £120 for the Sigma) - well, that's another matter...
Pentaxophile
Posted 19/06/2012 - 15:11 Link
You could look for an old thyristor auto flash (the Pentax AF280T comes to mind).. just engage red or green auto mode, and set the ISO and f-stop according to what the flash tells you. These flashguns are available on ebay for a few ££ if you are lucky so it's a low-risk dip-your-toe-into-flash.
DaveHolmes
Posted 19/06/2012 - 16:15 Link
I use YN560 both on and off-camera (using Cactus V4's) with my K-x...
Learning curve isn't too steep (imo) and its a powerful and pretty well made tool for the price...
I have no real need now for a Pttl/auto flash and can guess correct exposure to within one shot now... Often nailled on first shot...
Zack Arias (onelight) had a really good way of explaining manual flash exposure usage in easy to understand language...
Digital:
Flash:
Film:
Garnett
Posted 19/06/2012 - 16:57 Link
Pentaxophile - I'll need to read up on that option. Sounds interesting.
Dave, that sounds slightly less daunting than I had thought doing my reading. Do you have a link to the explanation you mention?
Edited by Garnett: 19/06/2012 - 16:58
DaveHolmes
Posted 19/06/2012 - 18:37 Link
OneLight is a DVD (I have a copied copy somewhere) but there are bits of it on youtube...
Essentially:
Aperture controls flash exposure if you get too much flash in the shot (ie; overexposed) close down your apereture... If too dark open it up... If you can't open it up, raise the ISO...
Shutterspeed controls your ambient light... If you don't want any, shoot at sync (1/180 on Pentax cameras) with low flashpower and subject close... If you're just wanting a bit of fill flash but ambient light is important, slow the shutter...
A couple hours practicing with a toy doll (or a rock in my case) should see you right... You kinda just have to learn to ignore the meter in the camera and go with your gut...
Both these are with the YN560... (sorry there so ugly... Can't choose your friends...)
Comment Image[img]http://farm8.staticflickr.com/7014/6687830809_a42532d3fc.jpg" class="comment_image" />
Ross by DaveHolmesPhotos, on Flickr[/img]
Comment Image[img]http://farm7.staticflickr.com/6050/6351294029_53dc5389e8.jpg" class="comment_image" />
Andy by DaveHolmesPhotos, on Flickr[/img]
This one was at Harewood House on a really bright day so it to was at sync (1/180)... The flash is quite obvious (partly due to my bad placement) but the blend between flash and ambient is ok...
Comment Image[img]http://farm3.staticflickr.com/2463/5816133619_fb77140b47.jpg" class="comment_image" />
A Seat Within Harewood Gardens by DaveHolmesPhotos, on Flickr[/img]
Digital:
Flash:
Film:
Garnett
Posted 20/06/2012 - 07:04 Link
Thanks Dave. Somenice flash use there. Whereabouts did you get your Cactus triggers?
DaveHolmes
Posted 20/06/2012 - 11:42 Link
After a lot of tealling I managed to find a UK supplier but for the life of me I can't seem to find again...
Gadget Infinity are your best bet though... By all accounts the V5 are vastly superior to my V4 set, but they do a sterling job and have held up well to bag abuse (they're left to rattle around frequently)
For me - flash is a bit of extra fun more than anything!
Digital:
Flash:
Film:
cabstar
Posted 20/06/2012 - 12:24 Link
I have the yn560 mk2s and they work fine on my k-5.
I bought two and one stopped working after a couple of weeks, sent it back to china and was replaced within a week.
They look really good and whilst they don't have pttl are really easy to use, a lot simpler than my Metz af48 which cost 3 times as much.
Concert photography
cabstar
Posted 20/06/2012 - 12:25 Link
Oh and if you shoot at 7fps the yn560mk2 keeps up when set below 1/8 power setting
Concert photography
Pentaxophile
Posted 20/06/2012 - 12:33 Link
Interesting alternative to the Yongnuos, Minolta 4000AF: http://www.pentaxforums.com/accessoryreviews/showproduct.php?product=1118&ca...
I just bought one for £1.20, plus £3.00 delivery! It seems pretty good so I got another from Rocky Cameras. Rather huge compared to modern flashes though, no 2nd curtain sync, but the power settings are there
surfhelds
Posted 20/06/2012 - 21:11 Link
Hey,
I'm using a Metz Mz40... And I like that flash a lot. Cheap but gooood!
One thing that's missing is HSS, but for now I can live without it.
cu Roddy
Pentax K5 with BG, Sigma 8-16mm, Sigma 30mm F1.4, Tamron 17-50mm F2.8, Pentaxx 50-135mm F2.8, Metz Mz40
Hochzeitsfotograf Seychellen
