Was I rash ?
Posted 13/08/2007 - 07:56
I guess if you like using manual lenses its a good buy. You will also need an adapter to if you plan on using them on your new K100D/K10
I had an old spottie and a couple of lenses given to me when i first got my K100D. Haven't purchased the adapter as yet.
Camera:|K-7|
Posted 13/08/2007 - 08:31
The Super Tak 28 mm f3.5 is reckoned to be a good 'un....
So, I'd put that to good use on the Spottie with a nice B&W film...
Posted 14/08/2007 - 02:46
I'm really enjoying reading up on the Pentax lenses then watching the interesting stream of second hand stuff come up online.I guess if you like using manual lenses its a good buy. You will also need an adapter to if you plan on using them on your new K100D/K10
I'm hoping to get an adapter setup on each so the K mounting will be seamless.
Will get the kit zoom too
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 14/08/2007 - 02:51
OK I read that the 200mm is ok too.The Super Tak 28 mm f3.5 is reckoned to be a good 'un....
am interested in trying some reverse lens macro.
The 360 Schneider is going to be fun
You are not wrong about shooting some film in the Spotmatic...
an B&W already has me engaged digitally
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 14/08/2007 - 10:47
The adapter is designed to convert the body to accept screw mount lenses rather than convert the lenses to fit a K mount body. You'll need only one adapter.I'm hoping to get an adapter setup on each so the K mounting will be seamless.
As far as I know, you can't remover the adapter and lens together. First you unscrew the lens, then remove the adapter from the body with a small 'spanner' which is usually supplied with the adapter.
Posted 15/08/2007 - 01:55
and fishing the thing off the body when I want the kit lens on..
I spose a fitting that contained the k mount mechanism would be thick and thus stuff up lens location...?
dang
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 15/08/2007 - 07:51
The K mount adapter is designed just as Mannesty describes.
If it were a thicker unit it would stop the lens focusing on infinity.
If you want to use screw thread lenses, then you do have to screw them on and off the camera.
Posted 15/08/2007 - 09:46
OK thanks !
looks like I will be having screw and bayonet days
cheers
Pete
cheers
Pete
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 15/08/2007 - 09:52
I am sure that if you asked him, Don would advise the following:
1 Remove the little springy strip on the adapter that locks it onto the body.
2 Glue the adapter to the lens. (You'll need one per lens.)
3 Drill a shallow hole in the base of the lens so that it, rather than the adapter, locks onto the body.
Voila, you have a bayonet-mount SMC Takumar.
Posted 15/08/2007 - 11:29
What a great idea George i will give that a go myself Thanks
Or should i say Don
Or should i say Don
Camera:|K-7|
Posted 15/08/2007 - 15:07
I love fixing things....
and that sounds like a workable idea....
also possible to lookup some collectors on the net or evilbay and see what you can get for em, put that towards new glass...
maybe somebody out there really wants to give them a home...
what does Mac from Montreal say?
Posted 16/08/2007 - 08:52
I like the sound of this
Has anyone ever made a wee tutorial for it ?
My experience of 'voila!' in the past has been variable
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 16/08/2007 - 08:54
Yes and no I love fixing things....
Pete
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 16/08/2007 - 10:00
Looks like you been shopping on Trademe. I always keep a close eye on things there and have got some excellent bargains. Go Canterbury! Cheers Gary
20 years
Whanganui New Zealand
I may resell the camera and a 55 to recoup a bit.
Did I do ok ?
Seems a bit silly with the K100/K10 as yet unpurchased
Pete
Pentax Asahi Spotmatic
35mm
4 lenses
Super-Takumar 1:3.5/28
Super-Takumar 1:4/200
Schneider Kreuznach tele xenar 1:5.5/360
Tamron MC Tele Converter 2x for Pentax
NOTE LENS IN GOOD CONDITON NO FUNGUS
some len
Close to the Edge
Down by the River
