Wanted: Older firmware (than 1.10) for optio 330
Anonymous
Posted 07/08/2005 - 17:26 Link
My optio 330 camera worked fine. I recently installed new firmware (version 1.10) on my camera. Now the camera isn't working, i can only acces a small menu when there is no card in the camera, and i can access the camera from my pc.
So there is hope, because i can still update firmware.
If anyone has the last firmware (1.9) please send it to me, i can then try to roll back (if that is possible). You can send it to: michielkroon at netscape dot net
George Lazarette
Posted 07/08/2005 - 22:16 Link
If I were you, I should try re-installing the new firmware. It is unlikely that it has a bug that would only affect your camera. What is far more likely is that the upgrade failed to install correctly.
I should download it again from the Pentax site, then try to re-install. Make sure you either have fresh batteries, or a mains connection. Power problems are known to ruin firmware updates.
Anonymous
Posted 07/08/2005 - 22:57 Link
Thanks for your comment, i tried reinstalling but it didn't work
George Lazarette
Posted 08/08/2005 - 00:04 Link
That's bad news. Hopefully somebody will have the version you want. I would suggest you try asking on DPReview as well as here.
