Vivitar 6000 Ring Flash on K20 or K200
bforbes
Posted 21/02/2010 - 10:31 Link
I've seen a thread about this flash on older Pentax DSLRs, but does anyone know it it's compatible with either the K20 or K200. I'm not sure what difference having P-TTL or TTL makes. A real novice with flash!!!
pink
Posted 21/02/2010 - 10:36 Link
Barrie
Try this link
and this is quoted
Weaknesses:
Cheap/plasticy feel. Doesn't seem to work on digital SLR cameras.
James
Mike-P
Posted 21/02/2010 - 10:57 Link
I think its fully manual on the K200D/K20D so you would fire on full power (unless the flash has power settings?). You would have to alter the brightness via aperture.
I may be wrong but thats how I use an small old normal TTL flash I carry.
Reuben0
Posted 21/02/2010 - 15:56 Link
pink wrote:
Weaknesses:
I have one of these and it works just fine (although it is definitely cheap and plasticy).
Just goes to show you shouldn't believe everything you read on the Internet
It supports TTL & Manual (at full power flash), but not P-TTL.
So on my *ist D you get full automation.
On other Pentax DSLR's you have to use it in Manual (ie vary the aperture & ISO to get the right exposure).
Given this is used for Macro where you tend to be a consistent distance from the subject, I haven't found this much of a problem!
R
Edited by Reuben0: 21/02/2010 - 16:16
bforbes
Posted 24/02/2010 - 22:50 Link
Reuben0 wrote:
pink wrote:
Weaknesses:
R
I've plumped for a Sunpak DX8R Ring Flash to get me started, as it was new from Devon Cameras, just waiting for the Pentax Shoe Module to arrive from the USA. Reading the Manual it has three modes Manual, Auto, and TTL. I understand TTL does not operate on K200 and K20, but what should I expect to happen if I set it to Auto.
Mannesty
Posted 24/02/2010 - 23:04 - Helpful Comment Link
Generally, a flash having one or more 'Auto' settings has a built-in light sensor to control the flash duration. This in turn controls the exposure.
bforbes
Posted 24/02/2010 - 23:13 Link
Does that mean you can set any aperture and shutter speed and the flash unit compensates itself? That sounds too easy!!
Telstar
Posted 24/02/2010 - 23:17 Link
I've just picked up a GX8R sunpak, though I have no manual for it, dont suppose yours covers that one too does it barrie? (probably not as the Gx8r is a bit long in the tooth now). Running mine from the pc port (as its voltage protected there) and seems to fire fine but i'm compensating manually in camera at the moment (or turning the flash output down.)
EDIT: forget the manual request Barrie, just looked up the Dx and its totally different from mine - very much more modern!
Bodies: GX20 | MZ-3 | MZ-M | Auto 110 complete kit
Primes: DA*300 F4 | DA40 F2.8 Ltd. | SMC-A 50/1.7 | Sigma 30mm F1.4 | Sirius 28/2.8
Macro : SMC-A Dental 100 macro
Zooms: 12-24 SA | 18-55 SA | 50-200 SA | 28-80 FA | 35-80 F | Vivitar 28-200
Other: Bellows | Tube sets | Vivitar 2x PK/A Tele | SEF-36PZF Flash | SBG-D1V Grip | Billingham 335
My Flickr
Edited by Telstar: 24/02/2010 - 23:19
gartmore
Posted 25/02/2010 - 09:13 - Helpful Comment Link
No, the flash will tell you to set an aperture relative to ISO so, for example, 5.6 @ 100ISO and 8 @ 200 ISO and so on. Having done that you just fire away.
bforbes
Posted 25/02/2010 - 10:09 Link
The flash manual talks about setting the camera shutter to the flash sync. speed. In the K20 manual I can only find reference to the sync. speed for the built in flash, is this the same for external flash units?
bretti_kivi
Posted 25/02/2010 - 10:16 - Helpful Comment Link
1/180, faster won't work.
my pics: link
gartmore
Posted 25/02/2010 - 11:56 Link
Set it to 'X' on the dial
bforbes
Posted 25/02/2010 - 17:59 Link
Does that mean I can not use it on the K200 with no 'X' on the dial?
Edited by bforbes: 25/02/2010 - 18:00
gartmore
Posted 25/02/2010 - 18:35 Link
Sorry I misread your post, I thought you had a K20. Anyway just set it to Manual and use 1/180 and whatever aperture the flash suggests.
bforbes
Posted 25/02/2010 - 20:27 Link
No you'r right Ken, I have both K20 and K200. Thank you for the help
