Vivitar 283 & K10D? Easiest usage?
Posted 05/02/2009 - 12:12
I bought the £16 wireless kit from the shop on this web site and it works very well. I had a fight to make it work without using the supplied PC cable but it seems to be a matter of using the locking mechanism.
If you ever want to sell the 283 think of me. I have my daughters scouring the car boot sales for them.
You really want to try and get the accessory that lets you manually adjust the power output as that gives you excellent control of a powerful flash gun.
Posted 05/02/2009 - 23:00
You could also use the internal flash to trigger an optical slave trigger on the hot shoe between the 283 and the bracket.
Digital: K20D+D-BG2 Grip, K10D+D-BG2 Grip, DA* 300 F4, DA* 50-135 F2.8, DA* 16-50 F2.8, DA 17-70 F4, DA 50-200, FA 100-300, AF540FGZ, F Remote release
Analogue: KM, 200mm M,135mm M, K 2x Conv, 28-80mm A, 55mm M, 28mm M, Vivitar 283
Other: Sony PC Digicam,2x Conv,0.7x Sea&Sea wide conv,Sea&Sea Underwater housing, GreenForce 2 x 50W HID lights + double capacity battery, Fujitsu F31 and Underwater housing, Nikon 7900+Underwater Housing
Posted 06/02/2009 - 09:01
Oh no you can't You could also use the internal flash to trigger an optical slave trigger on the hot shoe between the 283 and the bracket.
The internal pop up flash only does P-TTL... consequently the slaved flash will trigger on the preflash and have nothing for the main flash
Only if you get a "digital aware" slave cube that has a selectable ignore flash option
Ireland
Okay, by "easiest" in the title I meant "simplest" and by simplest "dumbest." ( I may not be a smart man, but I know what love is.)
