Viewing 35mm Slides
However I am not looking to 'copy' them, I just want to view them using something slightly more modern than my existing slide viewer and will then decide which are worthy of being scanned
I could use a lightbox, but you don't get any magnification.
I gave up looking at slides a long time ago, there are just too many....
However, I may revisit them at some point and they may be in better viewing condition than my archived digital files on CD.
..........................and they may be in better viewing condition than my archived digital files on CD.
I had a look at some of mine taken on my KX all those years ago and they are still in perfect condition, regardless of whther they are in their original cardboard / plastic mounts or are glass mounted
Why not buy a replacement projector from ebay? They go for fairly low prices...
Saves messing about with a projector screen and you can use the projectors single slide facility or simply run through a magazine full.
I would imagine the biggest problem with any slide projector now would be obtaining spare bulbs, I made sure I got a spare for mine
EDIT: typo
Reflecta still make projectors and one of their models has a screen + mirror as fatspider describes, although the screen is portrait, so landscape format slides would appear quite a bit smaller than portrait format ones.
I might look on ebay, although I am allergic to it
What I mean is if you used the very best scanner you could find 10 years ago the quality would probably not be that good so the slide would always be much higher quality.
If you were to re-scan now using a high quality scanner the improvement would be very significant.
Just before I went digital I bought a Braun Novomat with a pop up screen, the image is displayed on the screen via a mirror which you pop up in front of the lens (a bit like back projection) it gives a really bright image about 8inches across IIRC..................
Bernard
Remember Philips Video tape formats, betamax, 5.25" floppy disks, 3.5" floppy disks, LaserDisc.......
I load the slides (only three at a time/slide carrier) then quickly scan them - around 5 secs per slide, before reviewing in Photoshop. Those I don't want to keep go in the bin and the corresponding file is deleted.
The reason I do this is simply because I've found that the slide viewer just doesnt have the inherent quality to allow me to 'vet' the slide properly, and although this might seem a longer process overall I find there is a time saving through only handling the slides once.
Deepest Hampshire,
England
I spent part of the afternoon recovering some of my 35mm slide collection from long term storage, with a view to scanning some of them.
My slide projector died many years ago and I just have a basic Agfa slide viewer, so I thought I would look online at the modern versions of projectors and viewers.
I was really surprised to find that hardly anybody makes projectors and the slide viewers are incredibly basic.
I thought that somebody must by now be making projectors and slide viewers with an LED light source and other upgraded features, but no
