viewfinder question
Posted 18/07/2008 - 10:02
The DL2 (and other "low end" Pentax DSLRs) use a penta-mirror.
The higher end models (*ist-D, *ist-DS, K10D, K20D) use a penta-prism and the viewfinder is exceptionally clear. The pentaprism is more expensive and heavier but produces the type of viewfinder that you are probably used to seeing on older film cameras.
TBH, I don't there's much you can do for your existing viewfinder
(You can pick up reconditioned bodies from www.srsmicrosystems.co.uk, and second hand ones from various places. For example, www.lcegroup.co.uk have a couple of *ist-D bodies at around £200 with a lens.)
Posted 18/07/2008 - 10:22
Matt, thanks for the answer. Just to clarify, the experience that I got when looking through the 137 was akin to viewing my mates 47'' tv as opposed to my 32'' crt. If the analogy is clear, then the penta prism viewing experience should be appear lighter and bigger ?? Again, thanks the answer. Mark.
Posted 18/07/2008 - 11:29
Well, I'm not sure about the difference in size... I've only had a quick go at using my brother-in-law's *ist-DL and it was horrible in comparison to the *ist-D/DS pentaprism.
The Pentax viewfinders (pentaprism) are among the clearest out there. As far as I know there is no way of making it larger. I thought the magnified viewfinder attachment shows the centre of the image larger (for accurate manual focus), but effectively crops it.... but I could be wrong!!
Actually... just checking the specs on Bojidar's site...
The DL2 has a 0.85x magnification with 96% coverage.
The D/DS/K10D/K20D have a 0.95x magnification with 95% coverage.
So, yes, they'll appear larger and clearer
All the pentaprism bodies have 0.95x mag, and all the pentamirror have 0.85x
Posted 18/07/2008 - 11:54
And the optional magnified eyecup accessory will bring it up to 1.2.
Camera:|K-7|
Posted 18/07/2008 - 13:38
Do you have one? Can you see the whole VF?And the optional magnified eyecup accessory will bring it up to 1.2.
(Cause I'm very, very shortsighted and it could do with being a touch bigger!)
Posted 18/07/2008 - 13:55
yes i do and it makes a difference, i can see the whole view finder no probs including all the metering read outs at the bottom. . Just can't remember the the code name of it. Quote:
Cost about AU$40
Camera:|K-7|
Posted 18/07/2008 - 14:10
Just been Googling about it...
The Pentax one is the O-ME53.
There is also a Nikon one that fits - DK-21M which gives 1.17x magnification.
However, I have read that some have probs when wearing specs - ie not being able to see the whole frame and LED info
Clarky, I presume you don't wear specs?
Posted 18/07/2008 - 14:34
No i don't, Only to read. I will have a look with my reading glasses and get back to you. I'm at work at the moment.Just been Googling about it...
sockpuppet has the Nikon one !!
Camera:|K-7|
Posted 19/07/2008 - 05:45
Matt I tried looking through the view finder with my reading glasses on and did find it a little difficult to see the LCD readouts with them on. I had to keep moving my eye around to see everything.
Camera:|K-7|
Posted 19/07/2008 - 14:44
Now you know how all canon users feel.
Posted 23/07/2008 - 03:57
I was surprised at how bright the pentamirror viewfinder of the Canon 400D was that I recently had a go with. In fact it's brighter than than my Pentax K10D's pentaprism viewfinder - BUT it's much smaller. Personally, I'd rather have the larger one.
It seems you can't have something for nothing. If you have a cheaper and lighter pentamirror, depending on make/model, your view will be smaller or dimmer (or both) than a pentaprism view.
Foglio, I think you should seriously consider getting a DS, DS2, K10D or K20D. Used examples can be found on eBay, etc. Bear in mind though that the viewfinder still won't be as large as a Pentax 35mm film camera's.
~Pete
Posted 24/07/2008 - 18:59
I think that unless you buy a full frame digital SLR the viewfinder will always appear smaller when compared to a film SLR.
The viewfinder on my old Spotmatic is much larger and easier to use than on my K10D. Not everything has changed for the better....!!!
6th Year Apprentice Pensioner
