Vibration using bulb setting on Pentax K10D
Posted 15/05/2015 - 14:18
Hi Chris in the handbook it recommends that you turn off the shake reduction when using a tripod. It might be the shake reduction working ?. Derek
Posted 15/05/2015 - 14:29
Second Derek's suggestion
Chris
Posted 15/05/2015 - 14:32
Hi Derek,
Afraid not but thanks for the suggestion - I'm hoping it is something simple like a setting.
Regards,
Chris
Regards,
Chris
Posted 15/05/2015 - 14:44
does it have mirror lock up facility ? If yes have you tried this ?
Posted 15/05/2015 - 15:56
On a tripod I use the 'mirror up then 2 second delay' option in the drive settings. Plus no shake reduction as suggested. Your problem does sound a bit odd though.
Posted 15/05/2015 - 16:12
Hi Mike,
It does have a mirror lock up facility and it has exactly the same vibration when I use it.
Thanks,
Chris
Thanks,
Chris
Posted 15/05/2015 - 16:13
Not all the EXIF information is contained in the file you have posted (it's been pulled out by Adobe PS-CC). I could have sussed most of the required info from a full JPEG or RAW file.
Just tried the same action on a K10D here. No real difference between SR-On and SR-Off. I suspect SR has been disabled in Bulb mode. I can hear the magnets energised, making a very quiet purring noise - presumably as it keeps the sensor centred.
Do check what firmware version you have (I have v1.30).
Hold MENU down while powering up
Posted 15/05/2015 - 16:34
Hi Mike,
Thanks for your comment. It seems I am running version 1.0.
Having played with it for a bit I suspect the dust removal may be activating for some reason. I've tried deactivating it but still getting the same ticking so I could be wrong.
I tried to upload a RAW file but the uploader informs me it's the wrong type of file.
Regards,
Chris
Regards,
Chris
Posted 15/05/2015 - 17:00
Hi Chris,
I suggest you download firmware v1.30 and update your camera. Pretty sure there were SR issues that were fixed
http://www.ricoh-imaging.co.uk/en/Photo-Downloads.html#MediaTypeID4
See the Instructions and download the Windows installer
Posted 15/05/2015 - 17:04
Many thanks Matt,
Will try this.
Will try this.
Posted 17/05/2015 - 16:39
OK. Successfully updated to 1.31 - sadly still got the rocking. Thanks for trying Matt
Posted 17/05/2015 - 19:27
it's the solenoid holding the mirror up
Posted 10/07/2024 - 12:42
Did you ever resolve this? It's my biggest disappointment with my K10D--I used to love light painting with it, but can't do it now because it has exactly what you describe.
12 years
When I use my Pentax K10D in Bulb setting it makes a sort of ticking noise and produces a vibration which causes the effect like a heart trace seen in the picture of the car lights. The vibration is severe enough that if the camera is placed on a table it can be felt by placing your hand on the table top. Does anyone have any insight as to what is causing this and more importantly what if anything I can do to correct it please?
Many thanks in advance,
Chris
