velvia 50 advice came a settings
Take a good sturdy tripod then. The lens won't be at its sharpest at f22 but you will get the best depth of field.
Set the ISO (ASA) setting to 50 and see how you go. I also recommend a remote release and to lock the mirror up before you take each shot.
Ian
I haven't been able to find a remote so will use the timer.
Thx for the advice
www.left-I.com
Bjørn
I have picked a test landscape site for today which it pretty straight forward to shoot but I will under and over exp on the same shots to get the right balance and learn how to use .
I'll post some when developed . ( hopefully
www.left-I.com
I shot the above image in 1999. I used Velvia in a 1950s 6X9 Zeiss Ikonta with a 10.5cm coated Tessar lens. It was great fun and I even had the pleasure of processing the film myself. E6 kits were so cheap back then!
Ian
Once you've mastered a film like Velvia, the dynamic range of digital will never seem a problem again. It's a great exercise even if just from that point of view. All digital photographers should try at least one slide film. It will tighten up their composition skills and exposure skills.
Good advice! I could not agree more.
Set up at iso 40 and did a range of bracketed at a 1/3 and then some at iso 50 . Took a good amount to see when developed where I'm getting it right and wrong
Also had my canon along to shoot same location to see the difference
Thx for the help and lovely picture Ian
www.left-I.com
When bracketing transparencies, I usually do 1/2 stops rather than 1/3 stops and usually only in one direction (most of the time I know whether I need to err on under or over exposure).
Please share your results.
John.
ill get more up in the next couple of days
thx for all the help. any builds on this would be much appreciated
thx jonny
www.left-I.com
11 years
Novice to medium format having always been on dslr full frame .
I am out tomorrow doing landscapes , I have a 645n and have bought velvia 50 ( probably wrong first time film but ill persevere !!)
I could do with some advice on iso setting and exposure settings as I'm not clear on what I need to set up at.
It will be a good old bright day tomorrow and I'll be on aperture with high depth of field ( around 18 -22 )
Any help would be hugely appreciated
Thx Jonny
www.left-I.com
