UV filters
There has also been a debate on the forum in recent times about whether UV/Skylight filters should be used - it boils down to personal choice as the hood that comes with the lens should also provide protection from acidental damage.
I'm in the UV/Skylight filter user camp - old habits die hard as most of my lenses didn't come with a hood.
I myself use only B+W filters, they don't get stuck like most others and the glass is one of the best you can find.
I used to use UV filters but I don't buy them anymore, I always use an hood and the coating on the lens is extremely tough. It's easier to break the filter then to damage the glass although there are some situation where I can see you want to use a filter.
Why not buy a polarizer, that filter is atleast usefull when it is on the lens. It removes the haze so that colours are much more vibrant, the sky is a deeper blue and plants become greener and of course you can controll reflections. Yes they cost double the price but they are worth it I believe.
The filters you showed... I've so my doubt with them.
You have an expensive lens and you will probable downgrade the image quality with those filters. I don't know them but most cheap filters don't do so well but you might be lucky.
As my knowledge is low, I can't decide.
on Amazon for example HAze UV £18,90 , while Polarizinf £30 and 32 all on sale.
Help me please!
Pentax DA* 16-50mm f/2.8 | DA* 60-250mm f/4
Voigtlander Nokton 58mm f/1.4
My Flickr Link
Can I use them together or do I risk a degree of vignetting?
To aovid that, do you think is better to get a larger polarizer filter +adaptor or a thinner polarizer filter (the Pro1)?
I don't have the lens but stacking them might very well not give any vignetting, the filter size is quite large for such a lens you see so you dont need to worry much. Maybe if you use the lens wide open on the wide end it might be a problem but not when srtopped down or used on the long end. Once again I don't have the lens so dont take my word for it.
I guess the answer is to buy coated (i.e. 'Pro') filters.
(Update - from the later posts in this thread, I now know that the effect is called 'filter flare'.)
This point has been argued to death before. My argument is, why spend several hundreds of pounds on a quality lens, then screw a £20 piece of optically inferior glass on the front that is going to do nothing except reduce IQ, if only ever so slightly.
Do you not think that if the lens needed more protection, the manufacturers would include it?
In Pentax's case they do, it's called Super Multi-Coating.
Lenses should be cleaned only when necessary and then very carefully.
Here is someone who hates Canon so he's trying to break a lens link
Only with the end of the hammer he created some damage on the lens.
What John said is also true though but I believed many have an anti-scratch coating now. Will send Pentax a message about that and see what they will say.
By the way, that's not the recommended way to clean a Pentax lens!
Still, I wonder if it was on ebay later that day? "Mint, one careful owner."
Bristol
I've to buy an UV filter to protect the Sigma 17-70mm.
Even if the cost is not that high, can you recommend one type to me, please?
7days
dealextreme
kaidomain
